Info objects toString() method can return null, this is a break in the Object.toString contract. Reason being toString is returning this.name verbatim.
It's causing problems at least when setting up a unit test for a new resource, BaseWicketTester relies on it for GeoServerWicketTestSupport.print. May not be a big deal, but may be we should just fix the toString() implementations?
Gabriel
Gabriel Roldan ha scritto:
Agreed, breaking the api contract is a good reason along for a
fix. I guess using getClass().getSimpleName() + "(" + this.name + ")"
or something like that would do the trick?
Andrea Aime
OpenGeo - http://opengeo.org
Works for me.
-Justin
Justin Deoliveira
