the build in GeoServer has been down for the last few builds, with this test failure:
Tests run: 47, Failures: 2, Errors: 0, Skipped: 0, Time elapsed: 84.891 sec <<< FAILURE!
testGetCapabilitiesWithRestEndpointsAndDimensions(org.geoserver.gwc.GWCIntegrationTest) Time elapsed: 3332 sec <<< FAILURE!
org.junit.ComparisonFailure: expected:<[1]> but was:<[0]>
at org.junit.Assert.assertEquals(Assert.java:115)
at org.junit.Assert.assertEquals(Assert.java:144)
at org.geoserver.gwc.GWCIntegrationTest.testGetCapabilitiesWithRestEndpointsAndDimensions(GWCIntegrationTest.java:1840)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at java.lang.reflect.Method.invoke(Method.java:498)
testGetCapabilitiesRequestRestEndpoints(org.geoserver.gwc.GWCIntegrationTest) Time elapsed: 3957 sec <<< FAILURE!
org.junit.ComparisonFailure: expected:<[31]> but was:<[0]>
at org.geoserver.gwc.GWCIntegrationTest.testGetCapabilitiesRequestRestEndpoints(GWCIntegrationTest.java:1649)
As far as I can see the test fail because the capabliities backlink to http://localhost:8080/geoserver/geoserver/gwc/…."
(notice the double “geoserver” in the path).
I’m guessing this merge might be the cause, it’s related to path parsing and has been merged within the last day:
https://github.com/GeoWebCache/geowebcache/pull/619
However, not sure if the bug is in the newly merged code, or in the capabilities building code (could be both).
Could the involved people have a look? (I’m guessing Kevin and Nuno, but it’s just a guess)
== GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
I will have a look, thank you for the heads up.
On 06/13/2018 01:23 PM, Andrea Aime wrote:
Check out the vibrant tech community on one of the world's most
engaging tech sites, Slashdot.org! [http://sdm.link/slashdot](http://sdm.link/slashdot)
Geoserver-devel mailing list
[Geoserver-devel@lists.sourceforge.net](mailto:Geoserver-devel@lists.sourceforge.net)
[https://lists.sourceforge.net/lists/listinfo/geoserver-devel](https://lists.sourceforge.net/lists/listinfo/geoserver-devel)
Nuno Oliveira
Visit [http://goo.gl/it488V](http://goo.gl/it488V) for more information.
Nuno Miguel Carvalho Oliveira
@nmcoliveira
Software Engineer
[http://www.geo-solutions.it](http://www.geo-solutions.it)
[http://twitter.com/geosolutions_it](http://twitter.com/geosolutions_it)
Kevin and Nuno,
Jenkins geoserver-master has been broken in GWCIntegrationTest for two days. Will this be fixed on the GeoServer side or do we need to revert the GeoWebCache changes? Who is working on this?
https://build.geoserver.org/view/geoserver/job/geoserver-master/5922/consoleText
testGetCapabilitiesWithRestEndpointsAndDimensions(org.geoserver.gwc.GWCIntegrationTest) Time elapsed: 4486 sec <<< FAILURE!
testGetCapabilitiesRequestRestEndpoints(org.geoserver.gwc.GWCIntegrationTest) Time elapsed: 3539 sec <<< FAILURE!
Kind regards,
Ben.
Ben Caradoc-Davies <ben@anonymised.com>
Director
Transient Software Limited <https://transient.nz/>
New Zealand
Hi Ben, all,
Locally, removing this GWC commits (merger commit + commit) fixed the GeoServer build:
commit 86998e1e3c4b3eb75dbe90c6caebe93b2a11e733
commit 1f73e43c027423fef9009fb2ae6b7db9134c81a6
The related pull request is this one:
I was not involved with that PR so not sure what is going on, Kevin I’m passing the ball to you
Nuno Oliveira
On 06/14/2018 11:47 PM, Ben Caradoc-Davies wrote:
Kevin and Nuno,
Kind regards,
Ben.
Nuno Oliveira
@nmcoliveira
Software Engineer
So I tried to dig in to this and was stymied by classpath errors
involving unit-api in Eclipse that masked these failures. I eventually
switched to another machine. The problem was not what I initially
expected (needing to add Host headers to the Mock HTTP requests). It
looks like the patch does break things and need to be changed. I've
spent all the time I can spare on this so I've reverted it and let the
contributor know.
On 2018-06-15 02:03 AM, Nuno Oliveira wrote:
Hi Ben, all,
GeoServer build:
/I'm passing the ball/ to you
Nuno Oliveira
Kevin and Nuno,
at
at
Kind regards,
Ben.
this test failure:
at
Nuno Oliveira
@nmcoliveira
Software Engineer
Kevin Michael Smith
<smithkm@anonymised.com>
Thanks, Kevin. Much appreciated. The Jenkins geoserver-master build is now fixed.
Kind regards,
Ben.
contributor know.
Hi Ben, all,
GeoServer build:
Nuno Oliveira
Kevin and Nuno,
at
at
Kind regards,
Ben.
this test failure:
at
Nuno Oliveira
@nmcoliveira
Software Engineer
Director
New Zealand
