On Wed, Oct 14, 2015 at 11:23 AM, walter.nordmann <walter.nordmann@anonymised.com.>
wrote:
geowolf wrote
> What Jody really meant is, on this list there are over 2000 subscribers:
> what you are asking is more servlet containers related than GeoServer
> specific,
> there should be a lot of other users here that have an idea, but if none
> can/wants to help, there is always commercial support.
i agree, that the question is quite specific to ask on a dev-list, but here
are only two list (user and dev). So i asked both of them.
Ah, did not notice this was the devel list. Yeah, wrong list for such kind
of question,
a lot smaller audience, and here the discussion topic is only one,
how to improve GeoServer own code/functionality, it's a list by developers
for developers. You should ask on the users list instead.
btw: Who told you, that this is the preferred way? Do you see my problem?
Nobody told me is the preferred way. I've been a core developer of GeoServer
for 9 years now, and that's how I always did it (well, in some cases
also changed the web.xml file, but it's annoying to have to change it every
time
one upgrades GeoServer)
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
