[Geoserver-devel] Changing header/license to a couple of files, moving them from GS to GWC
Hi List,
I’m working on setting up support for MBTiles Layer on GWC as well as supporting a TileJSON document for that on WMTS.
https://github.com/GeoWebCache/geowebcache/issues/935
https://github.com/GeoWebCache/geowebcache/issues/941
While doing this, I’m planning to move the TileJSON and VectorLayerMetadata classes from geoserver/community/ogcapi (ogcapi-tiles) to geowebcache project.
https://github.com/geoserver/geoserver/blob/main/src/community/ogcapi/ogcapi-tiles/src/main/java/org/geoserver/ogcapi/tiles/TileJSON.java
https://github.com/geoserver/geoserver/blob/main/src/community/ogcapi/ogcapi-tiles/src/main/java/org/geoserver/ogcapi/tiles/VectorLayerMetadata.java
Therefore I will also need to modify the headers of these 2 files to be conform to the GWC headers.
So I’m here to ask permission to do that.
Please, let me know.
Daniele
Daniele Romagnoli
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
Ing. Daniele Romagnoli
Senior Software Engineer
Via di Montramito 3/A
This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
I’m the original author of both files, +1 on donating the source to GWC and subsequent license change
Regards, Andrea Aime
== GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
