[Geoserver-devel] charset problem
Hello,
My spatial datasets (oracle) have some string atributes written with
cyrillic (russian). And when i do GetFeature with GML2 as output format i
get ??? where text in cyrillic should be.
Example:
<table:atr0>??? ???</table:atr0>
It seems like a charset problem, but where? Geoserver/geotools or oracle
database?
View this message in context: http://www.nabble.com/charset-problem-tp15177244p15177244.html
Sent from the GeoServer - Dev mailing list archive at Nabble.com.
Can you verify that the data is stored properly in the database, by
doing a query from the command or some such.
I believe we ran into a similar issue recently with another database and
it was a problem with the jdbc driver. Which versions of oracle and
geoserver are you using?
GeoUser wrote:
Hello,
Example:
database?
Justin Deoliveira
The Open Planning Project
http://topp.openplans.org
Oracle is version 9, GS is version 1.5.x
jdeolive-2 wrote:
GeoUser wrote:
Hello,
Example:
database?
Justin Deoliveira
Defy all challenges. Microsoft(R) Visual Studio 2008.
Geoserver-devel mailing list
View this message in context: http://www.nabble.com/charset-problem-tp15177244p15200422.html
Just wanted to say that problem is fixed. There was a problem on the
database.
So how did you fix the problem?
jdeolive-2 wrote:
GeoUser wrote:
Hello,
i
Example:
database?
Justin Deoliveira
View this message in context: http://www.nabble.com/charset-problem-tp15177244p15263776.html
is it possible to obtain a thematic mapping as a WFS layer? I mean is it possible for WFS specification and is it provided by WFS implementation in Geoserver?
Thanks
Andrea Maschio
http://www.superandrew.it
Andrea Maschio ha scritto:
No, mapping is an exclusive of the WMS protocol. WFS is about providing raw data.
If you want to make thematic maps look into WMS GetMap and SLD
Hope this helps
Hope this helps
Of course it do, thanks Andrea. I wasn’t looking in the right place :slight_smile:
Thanks
