I have try dpi:96, also 90, and also another value, with the same result.
I have put my log to verbose. With or without format_option, I have an interesting Exception :
java.lang.NumberFormatException: empty String
at sun.misc.FloatingDecimal.readJavaFormatString(FloatingDecimal.java:1842)
at sun.misc.FloatingDecimal.parseFloat(FloatingDecimal.java:122)
at java.lang.Float.parseFloat(Float.java:451)
at org.jfree.eastwood.DataUtilities.parseSingleNumber(DataUtilities.java:204)
at org.jfree.eastwood.DataUtilities.parseTextData(DataUtilities.java:171)
at org.jfree.eastwood.DataUtilities.parsePieDataset(DataUtilities.java:343)
at org.jfree.eastwood.ChartEngine.buildChart(ChartEngine.java:520)
at org.jfree.eastwood.ChartEngine.buildChart(ChartEngine.java:155)
at org.geotools.renderer.chart.ChartGraphicFactory.getIcon(ChartGraphicFactory.java:71)
at org.geotools.renderer.style.SLDStyleFactory.getIcon(SLDStyleFactory.java:1319)
at org.geotools.renderer.style.SLDStyleFactory.getGraphicStyle(SLDStyleFactory.java:1238)
at org.geotools.renderer.style.SLDStyleFactory.createPointStyle(SLDStyleFactory.java:571)
(The full trace is long of 180 lignes, but we can see the call of ChartEngine here).
Without format_option I have this trace just once.
With format_option, twice.
Thank for all.
De : Jody Garnett <jody.garnett@…403…>
Envoyé : vendredi 24 septembre 2021 20:41
À : Jonathan DURAND <jonathan.durand@…7011…>
Cc : geoserver-devel@lists.sourceforge.net
Objet : [Ext] Re: [Geoserver-devel] charts extension and dpi fomart
First up, 35 dpi is … very low!
I am not so familiar with the chart code, do you have any kind of stack trace or other information beyond not showing the charts? Can you try with dpi:96 (matching the usual WMS default) so we can see if it is the format_option being applied at all, or just such an unusual number which is breaking the chart support.
Jody
On Fri, Sep 24, 2021 at 9:43 AM Jonathan DURAND <jonathan.durand@…7011…> wrote:
I use the charts extension in my geoserver instance.
https://docs.geoserver.geo-solutions.it/edu/en/pretty_maps/charting.html
I use some variables substitutions in my OnlineResource.
If I make a GetMap request, no problem.
But if I make a GetMap request with the DPI format argument (format_options=dpi:35), the result is broken. Not show the charts.
If there are no variables substitutions, no problem ; but I need my variables substitutions.
Do you know any solution ?
Thank you
Geoserver-devel mailing list
Jody Garnett
