[Geoserver-devel] Check list for jre8
I have just installed Oracle Corporation: 1.8.0_20 (Java HotSpot(TM) 64-Bit Server VM) and Geoserver 2.6-snapshot starts with it and all I have tried from the admin utility so far is OK. Do you developers know some features which are most likely to fail with jre8 so I could perhaps make some tests?
-Jukka Rahkonen-
I think we would have to try building with Java 8 and see what tests fail - in order to make a good guess on what features would fail.
Jody Garnett
On Fri, Sep 19, 2014 at 9:31 AM, Rahkonen Jukka (Tike) <jukka.rahkonen@anonymised.com> wrote:
I have just installed Oracle Corporation: 1.8.0_20 (Java HotSpot™ 64-Bit Server VM) and Geoserver 2.6-snapshot starts with it and all I have tried from the admin utility so far is OK. Do you developers know some features which are most likely to fail with jre8 so I could perhaps make some tests?
-Jukka Rahkonen-
Slashdot TV. Video for Nerds. Stuff that Matters.
http://pubads.g.doubleclick.net/gampad/clk?id=160591471&iu=/4140/ostg.clktrk
Geoserver-devel mailing list
