following on Jim’s work I’ve prepared a build that seems to be doing the trick, and building
in sequence:
- GeoTools (without tests, other builds cover that)
- GeoWebCache (with tests)
- GeoServer (with tests and community modules compile only)
All build in sequence in the same container, thus using the same repository and, what’s important,
the same snapshots produced by the GeoTools build.
Jim was right, making the silly thing build without breaking on build limits has been the challenging
point, took a number of experiments to find the right way to pass the JVM params and set them
to a working condition.
Build times are surprisingly not bad, around 20 minutes total, which is compatible with the other
Travis builds the PRs are triggering.
Here is the build file:
https://github.com/aaime/geotools/blob/circle/.circleci/config.yml
and branch:
https://github.com/aaime/geotools/tree/circle
A successful build looks as follows:
I’m sure some adjustments are going to be needed, and we won’t be able to trust these builds always
(like if a PR is meant to introduce a breaking change, well, it will break this build for sure).
I can imagine maybe some conventions in the commit message referring to the repos
and branches for the corresponding gwc and gs to use but… I’ll leave that as an exercise for those
interested :-p
If there are no objections I can make a PR to introduce this in GeoTools in the next few days.
PS: and yes, we’ll need to setup a similar build for GeoWebCache too, to check eventual downstream
breakage in GeoServer.
== GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
