[Geoserver-devel] Cite compliance mode working only for wfs when using geoserver/wfs?
I was looking around and to my horror I’ve found that the cite compliance field
gets set in the dispatcher only when using the wfs protocol and the
geoserver/wfs path:
**dispatcher** __dispatcher__ **wfsTestServlet**
Blek… it means that all other service are not covered, and that when using
ows not even wfs is.
I guess that to have this work for all services a significant rework would be
in order?
Meet us at GEO Business 2014! in London! Visit http://goo.gl/fES3aK
for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Ah, actually this works also for CSW on the geoserver/csw path… but regardless… the way this works
breaks when people use ows, as we cannot statically associate a service class to it…
On Thu, May 1, 2014 at 12:11 PM, Andrea Aime <andrea.aime@anonymised.com> wrote:
geoserver/wfs path:
in order?
Ing. Andrea Aime
@geowolf
Technical Lead
Ing. Andrea Aime
@geowolf
Technical Lead
Hmmm… not sure why it was done that way… maybe because WFS was the only service that needed the cite compliance hacks to pass cite? Not sure. The way it is implemented has other issues as well… it uses a field on the dispatcher itself which totally has concurrency issues… truly a hack as its name indicates :slight_smile:
Perhaps we can do this. Instead of making the CiteComplianceHack class a HandlerINterceptor let’s make it a dispatcher callback. And let’s remove the citeCompliant field from the dispatcher and move it to the Request class. Then the dispatcher callback can set it there.
On Thu, May 1, 2014 at 4:12 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
“Accelerate Dev Cycles with Automated Cross-Browser Testing - For FREE
Instantly run your Selenium tests across 300+ browser/OS combos. Get
unparalleled scalability from the best Selenium testing platform available.
Simple to use. Nothing to install. Get started now for free.”
http://p.sf.net/sfu/SauceLabs
Geoserver-devel mailing list
Justin Deoliveira
Vice President, Engineering | Boundless
jdeolive@anonymised.com
@j_deolive
geoserver/wfs path:
in order?
Ing. Andrea Aime
@geowolf
Technical Lead
Ing. Andrea Aime
@geowolf
Technical Lead
On Thu, May 1, 2014 at 3:17 PM, Justin Deoliveira <jdeolive@anonymised.com
wrote:
Hmmm... not sure why it was done that way... maybe because WFS was the
The way it is implemented has other issues as well... it uses a field on
the dispatcher itself which totally has concurrency issues... truly a hack
HandlerINterceptor let's make it a dispatcher callback. And let's remove
Maybe we can go one step further and fold this change into this pull
request:
https://github.com/geoserver/geoserver/pull/574
(I'm still working on it, to take into account acceptVersions when the
dispatcher does not get a version and the request is a GetCapabiltiies).
As far as I can see at the end of the day all the flag is doing is to end
up complaining
if service/version params are missing (or just service if the request is a
GetCapabilties).
With the new originalService/originalVersion fields the dispatcher callback
can actually do
all the work, see if the params are missing, if so lookup the service
object, check if the
strict cite compliance is set, and throw the exception
Ing. Andrea Aime
@geowolf
Technical Lead
On Thu, May 1, 2014 at 11:15 AM, Andrea Aime
request:
Hmmm... not sure if it makes sense to conflate them.
up complaining
GetCapabilties).
callback can actually do
Well at the moment the configuration flag is per service right? The reason
the hack was done like that (as an interceptor) was so that the Dispatcher
could remain ignorant of individual service configuration.
Ing. Andrea Aime
@geowolf
Technical Lead
*Justin Deoliveira*
@j_deolive <https://twitter.com/j_deolive&gt;
On Fri, May 2, 2014 at 4:29 PM, Justin Deoliveira <jdeolive@anonymised.com
wrote:
On Thu, May 1, 2014 at 11:15 AM, Andrea Aime <andrea.aime@anonymised.com
request:
Imho it's the only way forward for capabilities requests, where we don't
have a target version. This way:
* We pick an allowed service version and kvp parsers directly in the
dispatcher
* Do not rely on the capabilities implementation to delegate on older
versions, the way things are implemented
  now is that the service running the caps has to know all newer and older
versions and delegate to the right one using
  acceptsVersions... some services do it right (wfs), others only partially
(wcs), some not at all (wms).
  Since acceptVersions is uniform in all specs, this also removes the need
to code a common part in all services,
  we can do it right in a single place
The current broken-ness is not visible only because the CITE tests are not
doing version negotiation checks.
up complaining
a GetCapabilties).
Of course, and the dispatcher callback would pick up the right ServiceInfo
and do the checks leaving the Dispatcher ignorant
Chers
Ing. Andrea Aime
@geowolf
Technical Lead
On Fri, May 2, 2014 at 8:41 AM, Andrea Aime <andrea.aime@anonymised.com>wrote:
a HandlerINterceptor let's make it a dispatcher callback. And let's remove
request:
dispatcher
partially (wcs), some not at all (wms).
OK, works for me.
end up complaining
a GetCapabilties).
reason the hack was done like that (as an interceptor) was so that the
Dispatcher could remain ignorant of individual service configuration.
Chers
Ing. Andrea Aime
@geowolf
Technical Lead
*Justin Deoliveira*
