I have been doing CITE tests at the moment for a new patch I made. After making changes to my code I am left with one test that seems to fail and is (I think) unrelated to anything I have done (the tests also fail with the latest trunk version of geoserver):
Test wfs:wfs-1.1.0-Basic-GetFeature-tc302.1 (s0005/d1e34902_1/d1e732_1/d1e25206_1/d1e16209_1/d1e12726_1)
Assertion: All supported (including arithmetic) functions should be defined in the service capabilities document. A defined function accepts 0 or more arguments and returns a single value.
Request d1e13072_1:
Method: post
URL: [http://localhost:7070/geoserver/wfs](http://localhost:7070/geoserver/wfs)
Body:
<wfs:GetFeature xmlns=["http://www.occamlab.com/ctl"](http://www.occamlab.com/ctl) xmlns:ctl=["http://www.occamlab.com/ctl"](http://www.occamlab.com/ctl)
xmlns:gml=["http://www.opengis.net/gml"](http://www.opengis.net/gml)
xmlns:myparsers=["http://teamengine.sourceforge.net/parsers"](http://teamengine.sourceforge.net/parsers)
xmlns:ogc=["http://www.opengis.net/ogc"](http://www.opengis.net/ogc)
xmlns:ows=["http://www.opengis.net/ows"](http://www.opengis.net/ows)
xmlns:p=["http://teamengine.sourceforge.net/parsers"](http://teamengine.sourceforge.net/parsers)
xmlns:parsers=["http://www.occamlab.com/te/parsers"](http://www.occamlab.com/te/parsers)
xmlns:saxon=["http://saxon.sf.net/"](http://saxon.sf.net/)
xmlns:sf=["http://cite.opengeospatial.org/gmlsf"](http://cite.opengeospatial.org/gmlsf)
xmlns:te=["http://www.occamlab.com/te"](http://www.occamlab.com/te)
xmlns:tec="java:com.occamlab.te.TECore"
xmlns:wfs=["http://www.opengis.net/wfs"](http://www.opengis.net/wfs)
xmlns:xi=["http://www.w3.org/2001/XInclude"](http://www.w3.org/2001/XInclude)
xmlns:xlink=["http://www.w3.org/1999/xlink"](http://www.w3.org/1999/xlink)
xmlns:xs=["http://www.w3.org/2001/XMLSchema"](http://www.w3.org/2001/XMLSchema)
xmlns:xsd=["http://www.w3.org/2001/XMLSchema"](http://www.w3.org/2001/XMLSchema)
xmlns:xsi=["http://www.w3.org/2001/XMLSchema-instance"](http://www.w3.org/2001/XMLSchema-instance)
service="WFS"
version="1.1.0">
<wfs:Query srsName="urn:x-ogc:def:crs:EPSG:4326" typeName="sf:PrimitiveGeoFeature">
<ogc:Filter>
<ogc:PropertyIsEqualTo>
<ogc:PropertyName>sf:decimalProperty</ogc:PropertyName>
<ogc:Sub>
<ogc:PropertyName>sf:intProperty</ogc:PropertyName>
<ogc:Literal>149.98</ogc:Literal>
</ogc:Sub>
</ogc:PropertyIsEqualTo>
</ogc:Filter>
</wfs:Query>
</wfs:GetFeature>
Response from parser p:XMLValidatingParser.GMLSF1:
<ows:ExceptionReport xmlns:ows=["http://www.opengis.net/ows"](http://www.opengis.net/ows)
version="1.0.0"
xsi:schemaLocation=["http://www.opengis.net/ows http://localhost:7070/geoserver/schemas/ows/1.0.0/owsExceptionReport.xsd"](http://www.opengis.net/owshttp://localhost:7070/geoserver/schemas/ows/1.0.0/owsExceptionReport.xsd)>
<ows:Exception exceptionCode="NoApplicableCode">
<ows:ExceptionText>java.lang.RuntimeException: java.io.IOException
java.io.IOException
null
ERROR: invalid input syntax for integer: &quot;149.98&quot;
Position: 115</ows:ExceptionText>
</ows:Exception>
</ows:ExceptionReport>
Subtest s0005/d1e34902_1/d1e732_1/d1e25206_1/d1e16209_1/d1e12726_1/d1e13128_1 Failed
Subtest s0005/d1e34902_1/d1e732_1/d1e25206_1/d1e16209_1/d1e12726_1/d1e13138_1 Failed
Subtest s0005/d1e34902_1/d1e732_1/d1e25206_1/d1e16209_1/d1e12726_1/d1e13149_1 Failed
Result: Failed (Inherited Failure)
Niels Charlier
Software Engineer
CSIRO Earth Science and Resource Engineering
Phone: +61 8 6436 8914
Australian Resources Research Centre
26 Dick Perry Avenue, Kensington WA 6151
