[Geoserver-devel] CITE Test wfs 1.1.0
While doing this test, I come across this error. Looks like schema error. Can
someone help?
13 May 17:48:20 INFO [org.geoserver] - Loaded default workspace
it.geosolutions
13 May 17:48:20 INFO [org.geoserver] - Loaded workspace 'it.geosolutions'
13 May 17:48:20 INFO [org.geoserver] - Loaded workspace 'sf'
13 May 17:48:20 WARN [org.geoserver] - Ignoring store directory 'prop-base'
13 May 17:48:20 WARN [org.geoserver] - Ignoring store directory 'props'
13 May 17:48:20 WARN [org.geoserver] - Ignoring store directory 'text-base'
13 May 17:48:20 WARN [org.geoserver] - Ignoring store directory 'tmp'
13 May 17:48:20 WARN [org.geoserver] - Ignoring store directory '.svn'
13 May 17:48:20 INFO [org.geoserver] - Loaded store 'sf', enabled
13 May 17:48:20 INFO [org.geoserver] - Loaded data store 'sf'
13 May 17:48:20 TRACE [org.geotools.resources] - Loaded resources for
English from bundle "org.geotools.resources.i18n".
13 May 17:48:20 INFO [org.geotools.factory] - Factory implementations for
category DataStoreFactorySpi:
  org.geotools.data.property.PropertyDataStoreFactory
  org.geotools.data.shapefile.ShapefileDataStoreFactory
  org.geotools.data.wfs.WFSDataStoreFactory
  org.geotools.data.h2.H2DataStoreFactory
  org.geotools.data.h2.H2JNDIDataStoreFactory
  org.geotools.data.postgis.PostgisNGDataStoreFactory
  org.geotools.data.postgis.PostgisNGJNDIDataStoreFactory
  org.geotools.data.directory.DirectoryDataStoreFactory
13 May 17:48:21 INFO [org.geotools.factory] - Factory implementations for
category FilterFactory:
  org.geotools.filter.FilterFactoryImpl
category FeatureFactory:
  org.geotools.feature.LenientFeatureFactoryImpl
  org.geotools.feature.ValidatingFeatureFactoryImpl
13 May 17:48:21 DEBUG [org.geotools.jdbc] - CREATE CONNECTION
13 May 17:48:22 DEBUG [org.geotools.jdbc] - CLOSE CONNECTION
13 May 17:48:22 WARN [org.geoserver] - Ignoring feature type directory
C:\VWork\CITETESTTOOL\data\citewfs-1.1-h2\workspaces\sf\sf\.svn
13 May 17:48:22 TRACE [org.geotools.resources] - Loaded resources for
13 May 17:48:22 INFO [org.geotools.factory] - Factory implementations for
category CRSFactory:
  org.geotools.referencing.factory.ReferencingObjectFactory
category DatumFactory:
  org.geotools.referencing.factory.DatumAliases
category MathTransformFactory:
  org.geotools.referencing.operation.DefaultMathTransformFactory
13 May 17:48:22 DEBUG [org.geotools.referencing.factory] - Loading datum
aliases from
"jar:file:/C:/Documents%20and%20Settings/tey006/.m2/repository/org/geotools/gt-referencing/2.6-SNAPSHOT/gt-referencing-2.6-SNAPSHOT.jar!/org/geotools/referencing/factory/DatumAliasesTable.txt".
category CSFactory:
category CRSAuthorityFactory:
  org.vfny.geoserver.crs.GeoserverCustomWKTFactory
  org.vfny.geoserver.crs.GeoserverOverridingWKTFactory
  org.geotools.referencing.factory.epsg.DefaultFactory
  org.geotools.referencing.factory.epsg.FactoryUsingWKT
  org.geotools.referencing.factory.epsg.LongitudeFirstFactory
  org.geotools.referencing.factory.wms.AutoCRSFactory
  org.geotools.referencing.factory.wms.WebCRSFactory
  org.geotools.referencing.factory.URN_AuthorityFactory
  org.geotools.referencing.factory.HTTP_AuthorityFactory
  org.geotools.referencing.factory.epsg.LongitudeFirstEpsgDecorator
  org.geotools.referencing.factory.epsg.ThreadedHsqlEpsgFactory
13 May 17:48:22 INFO [org.geotools.referencing.factory] - Using
"/C:/VWork/CITE%20Test/GeoServer/src/main/target/test-classes/org/vfny/geoserver/crs/override_epsg.properties"
as EPSG factory.
13 May 17:48:22 WARN [org.geotools.referencing.factory] - Axis elements
found in a wkt definition, the force longitude first axis order hint might
not be respected:
PROJCS["Monte Mario / Italy zone 1", GEOGCS["Monte Mario", DATUM["Monte
Mario", SPHEROID["International 1924", 6378388.0, 297.0,
AUTHORITY["EPSG","7022"]],
TOWGS84[-104.1,-49.1,-9.9,0.971,-2.917,0.714,-11.68],
AUTHORITY["EPSG","6265"]], PRIMEM["Greenwich", 0.0,
AUTHORITY["EPSG","8901"]], UNIT["degree", 0.017453292519943295],
AXIS["Geodetic longitude", EAST], AXIS["Geodetic latitude", NORTH],
AUTHORITY["EPSG","4265"]], PROJECTION["Transverse Mercator",
AUTHORITY["EPSG","9807"]], PARAMETER["central_meridian", 9.0],
PARAMETER["latitude_of_origin", 0.0], PARAMETER["scale_factor", 0.9996],
PARAMETER["false_easting", 1500000.0], PARAMETER["false_northing", 0.0],
UNIT["m", 1.0], AXIS["Easting", EAST], AXIS["Northing", NORTH],
AUTHORITY["EPSG","3003"]]
13 May 17:48:23 INFO [org.geotools.referencing.factory] - Connected to EPSG
database
"jdbc:hsqldb:file:/C:/DOCUME~1/tey006/LOCALS~1/Temp/Geotools/Databases/HSQL/v7.4.0/EPSG"
on "HSQL Database Engine".
13 May 17:48:23 TRACE [org.geotools.resources] - Loaded resources for
13 May 17:48:23 INFO [org.geotools.referencing.factory] - Using
"/C:/VWork/CITE%20Test/GeoServer/src/main/target/classes/org/vfny/geoserver/crs/user_epsg.properties"
as EPSG factory.
13 May 17:48:23 DEBUG [org.geotools.referencing.factory] - Failure in the
primary factory: No code "EPSG:4326" from authority "European Petroleum
Survey Group" found for object of type "IdentifiedObject". Now trying the
fallback factory...
13 May 17:48:23 INFO [org.geoserver] - Loaded feature type
'AggregateGeoFeature', enabled
13 May 17:48:23 INFO [org.geoserver] - Loaded feature type 'sf'
13 May 17:48:23 INFO [org.geoserver] - Loaded layer 'AggregateGeoFeature'
'EntitéGénérique', enabled
13 May 17:48:23 INFO [org.geoserver] - Loaded layer 'EntitéGénérique'
'PrimitiveGeoFeature', enabled
13 May 17:48:23 INFO [org.geoserver] - Loaded layer 'PrimitiveGeoFeature'
13 May 17:48:24 INFO [org.geoserver] - Loaded service 'wfs', enabled
13 May 17:48:24 INFO [org.geoserver] - Loaded service 'wms', enabled
13 May 17:48:24 INFO [org.geoserver] - Loaded service 'wcs', enabled
13 May 17:48:24 TRACE [org.geotools.resources] - Loaded resources for
13 May 17:48:24 INFO [org.geotools.image.jai] - Native acceleration disabled
for "Mosaic" operation.
13 May 17:48:25 INFO [org.geotools.factory] - Factory implementations for
category StyleFactory:
  org.geotools.styling.StyleFactoryImpl
13 May 17:48:25 TRACE [org.geotools.resources] - Loaded resources for
category CoordinateOperationFactory:
  org.geotools.referencing.operation.DefaultCoordinateOperationFactory
  org.geotools.referencing.operation.AuthorityBackedFactory
  org.geotools.referencing.operation.BufferedCoordinateOperationFactory
category CoordinateOperationAuthorityFactory:
13 May 17:48:26 ERROR [org.geowebcache.config.XMLConfiguration] -
Configuration file cannot be read or does not exist!
13 May 17:48:26 ERROR [org.geowebcache.layer.TileLayerDispatcher] -
Configuration C:\VWork\CITE
Test\GeoServer\src\web\app\src\main\webapp\..\resources contained no layers.
13 May 17:48:26 ERROR [org.geowebcache.layer.TileLayerDispatcher] - Error
reading service information from C:\VWork\CITE
Test\GeoServer\src\web\app\src\main\webapp\..\resources: Error parsing file
C:\VWork\CITE
Test\GeoServer\src\web\app\src\main\webapp\..\resources\geowebcache.xml
13 May 17:48:53 INFO [org.geoserver.wfs] -
Request: getServiceInfo
13 May 17:48:54 INFO [org.geoserver.wfs] -
Request: getCapabilities
  acceptVersions:
    version = [1.1.0]
  sections = null
  acceptFormats = null
  updateSequence = null
  baseUrl = http://localhost:8080/geoserver/
  namespace = null
  service = wfs
  acceptVersions:
    version = [1.1.0]
  sections = null
  namespace = null
  service = WFS
13 May 17:48:55 INFO [org.geoserver.wfs] -
13 May 17:48:56 DEBUG [org.geotools.jdbc] - CREATE CONNECTION
13 May 17:48:56 DEBUG [org.geotools.jdbc] - CLOSE CONNECTION
13 May 17:48:56 WARN [org.geoserver.wfs] - Could not load underlying feature
type for type AggregateGeoFeature
java.io.IOException: Schema
'http://cite.opengeospatial.org/gmlsf:AggregateGeoFeature’ does not exist.
  at
org.geotools.data.store.ContentDataStore.ensureEntry(ContentDataStore.java:591)
  at
org.geotools.data.store.ContentDataStore.getFeatureSource(ContentDataStore.java:381)
  at
org.geotools.data.store.ContentDataStore.getFeatureSource(ContentDataStore.java:348)
  at
org.geotools.data.store.ContentDataStore.getSchema(ContentDataStore.java:333)
  at org.mortbay.jetty.handler.HandlerWrapper.handle(HandlerWrapper.java:152)
  at org.mortbay.jetty.Server.handle(Server.java:324)
  at org.mortbay.jetty.HttpConnection.handleRequest(HttpConnection.java:505)
  at
org.mortbay.jetty.HttpConnection$RequestHandler.content(HttpConnection.java:842)
  at org.mortbay.jetty.HttpParser.parseNext(HttpParser.java:648)
  at org.mortbay.jetty.HttpParser.parseAvailable(HttpParser.java:211)
  at org.mortbay.jetty.HttpConnection.handle(HttpConnection.java:380)
  at
org.mortbay.jetty.bio.SocketConnector$Connection.run(SocketConnector.java:228)
  at
org.mortbay.thread.BoundedThreadPool$PoolThread.run(BoundedThreadPool.java:450)
type for type EntitéGénérique
'http://cite.opengeospatial.org/gmlsf:EntitéGénérique' does not exist.
  at
  at
  at
  at
  at
  at
type for type PrimitiveGeoFeature
'http://cite.opengeospatial.org/gmlsf:PrimitiveGeoFeature’ does not exist.
  at
  at
  at
  at
  at
  at
13 May 17:48:56 DEBUG [org.geotools.xml] - No schemaLocation found, using
'http://www.opengis.net/wfs
file:/C:/VWork/CITE%20Test/GeoServer/src/wfs/target/classes/org/geoserver/wfs/xml/v1_1_0/wfs.xsd
13 May 17:48:56 DEBUG [org.geotools.xml] - Found override for
http://www.opengis.net/wfs:
13 May 17:48:56 DEBUG [org.geotools.xml] - building schema for schema:
13 May 17:48:57 DEBUG [org.geotools.xml] - building schema for schema:
http://www.opengis.net/ows
13 May 17:48:57 DEBUG [org.geotools.xml] - Could not locate schema for:
owsGetCapabilities.xsd.
owsServiceIdentification.xsd.
owsDataIdentification.xsd.
owsCommon.xsd.
http://www.w3.org/1999/xlink
ows19115subset.xsd.
owsServiceProvider.xsd.
ows19115subset.xsd.
owsOperationsMetadata.xsd.
owsCommon.xsd.
ows19115subset.xsd.
owsExceptionReport.xsd.
http://www.opengis.net/ogc
expr.xsd.
sort.xsd.
expr.xsd.
filterCapabilities.xsd.
http://www.opengis.net/gml
13 May 17:48:58 DEBUG [org.geotools.xml] - Could not locate schema for:
dynamicFeature.xsd.
feature.xsd.
geometryBasic2d.xsd.
geometryBasic0d1d.xsd.
measures.xsd.
units.xsd.
dictionary.xsd.
gmlBase.xsd.
basicTypes.xsd.
temporal.xsd.
gmlBase.xsd.
direction.xsd.
topology.xsd.
geometryComplexes.xsd.
geometryAggregates.xsd.
geometryPrimitives.xsd.
coverage.xsd.
feature.xsd.
valueObjects.xsd.
temporal.xsd.
grids.xsd.
13 May 17:48:59 DEBUG [org.geotools.xml] - Could not locate schema for:
coordinateReferenceSystems.xsd.
coordinateSystems.xsd.
referenceSystems.xsd.
temporal.xsd.
datums.xsd.
coordinateOperations.xsd.
dataQuality.xsd.
units.xsd.
observation.xsd.
feature.xsd.
direction.xsd.
valueObjects.xsd.
defaultStyle.xsd.
measures.xsd.
../smil/smil20.xsd.
13 May 17:48:59 DEBUG [org.geotools.xml] - building schema for schema:
http://www.w3.org/XML/1998/namespace
smil20-language.xsd.
smil20.xsd.
temporalReferenceSystems.xsd.
temporalTopology.xsd.
temporal.xsd.
dictionary.xsd.
13 May 17:48:59 DEBUG [org.geotools.jdbc] - CREATE CONNECTION
13 May 17:48:59 DEBUG [org.geotools.jdbc] - CLOSE CONNECTION
13 May 17:48:59 WARN [org.geoserver.wfs] - Unable to get schema location for
feature type 'sf:AggregateGeoFeature'. Reason: 'Schema
'http://cite.opengeospatial.org/gmlsf:AggregateGeoFeature’ does not exist.'.
Building the schema manually instead.
13 May 17:48:59 DEBUG [org.geotools.xml] - Could not resolve schema
feature type 'sf:EntitéGénérique'. Reason: 'Schema
'http://cite.opengeospatial.org/gmlsf:EntitéGénérique' does not exist.'.
13 May 17:48:59 WARN [org.geoserver.wfs] - Could not build xml schema for
type: EntitéGénérique
  at
  at
View this message in context: http://old.nabble.com/CITE-Test-wfs-1.1.0-tp28545646p28545646.html
Sent from the GeoServer - Dev mailing list archive at Nabble.com.
someone help?
It's not like I remember this error exactly, but I would suggest to check that both the file system and the postgis database are storing
information in UTF-8 (e.g., that they can deal with the accents)
Andrea Aime
OpenGeo - http://opengeo.org
It sort of looks like the underlying database has not been loaded with the necessary data? Are you running the postgis or h2 configuration?
someone help?
it.geosolutions
aliases from
category CSFactory:
as EPSG factory.
not be respected:
database
as EPSG factory.
fallback factory...
C:\VWork\CITE
  acceptVersions:
    version = [1.1.0]
  sections = null
  namespace = null
  service = wfs
  acceptVersions:
    version = [1.1.0]
  sections = null
  namespace = null
  service = WFS
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
owsCommon.xsd.
ows19115subset.xsd.
ows19115subset.xsd.
owsCommon.xsd.
ows19115subset.xsd.
expr.xsd.
sort.xsd.
expr.xsd.
dynamicFeature.xsd.
feature.xsd.
measures.xsd.
units.xsd.
dictionary.xsd.
gmlBase.xsd.
basicTypes.xsd.
temporal.xsd.
gmlBase.xsd.
direction.xsd.
topology.xsd.
coverage.xsd.
feature.xsd.
valueObjects.xsd.
temporal.xsd.
grids.xsd.
temporal.xsd.
datums.xsd.
dataQuality.xsd.
units.xsd.
observation.xsd.
feature.xsd.
direction.xsd.
valueObjects.xsd.
defaultStyle.xsd.
measures.xsd.
../smil/smil20.xsd.
smil20.xsd.
temporal.xsd.
dictionary.xsd.
  at
  at
Justin Deoliveira
They are in UTF-8
I am running the H2 configuration according to
http://docs.geoserver.org/stable/en/developer/cite-test-guide/index.html
According to the doc, I am only required to unzip the cite.db file? Is there
more steps I am required to do?
I have tried the steps in the readme.txt in wfs1.1.0-h2 directory as well
but to no avail. I am getting the same error. To load the data into the h2
db, what is required?
Can someone pls elaborate a bit?
View this message in context: http://old.nabble.com/CITE-Test-wfs-1.1.0-tp28545646p28555153.html
They are in UTF-8
Last time I tried to run cite tests over H2 there were extra requirements:
https://svn.codehaus.org/geoserver/branches/2.0.x/data/citewfs-1.1-h2/README.txt
Andrea Aime
I have tried those as well. I gave up on the H2 and is currently using the
wfs1.1.0
51 errors and 400+ passes. Not sure where to go from there and will consult
Ben when I see him.
For wcs1.0 testing, the following warning
Warning The WCS specification does not allow a cite compliant WCS 1.0 and
1.1 version to co-exist. To successfully run the WCS 1.0 cite tests the
wms1_1-<VERSION>.jar must be removed from the geoserver WEB-INF/lib
directory.
Am I suppose to remove wms or wcs 1.1 ?
They are in UTF-8
there
h2
Andrea Aime
Geoserver-devel mailing list
View this message in context: http://old.nabble.com/CITE-Test-wfs-1.1.0-tp28545646p28555759.html
directory.
I warned you that you would find all the bugs in the manual. :wink:
You should submit documentation patches via codehaus Jira. Mike Pumphrey is, I think, the maintainer. The source is in the doc subdirectory.
Ben Caradoc-Davies <Ben.Caradoc-Davies@anonymised.com>
Software Engineering Team Leader
CSIRO Earth Science and Resource Engineering
Australian Resources Research Centre
wfs1.1.0
Ben when I see him.
directory.
wcs 1.1
Andrea Aime
They are in UTF-8
Old instructions. I opted for just including a zip file in the data directory that contained a fresh database. Apologies for updating the readme.
Justin Deoliveira
wfs1.1.0
The only other thing I can think of is that you do not have the h2 extension active when you are running the tests. But yeah, the regular wfs 1.1.0 configuration works just as well.
Ben when I see him.
directory.
They are in UTF-8
there
h2
Andrea Aime
Justin Deoliveira
wfs1.1.0
Justin, I tried it out and does not work for me either.
I do have the h2 extension active, but the thing is, the workspaces
in that data dir are an external that picks from
https://svn.codehaus.org/geoserver/branches/2.0.x/data/citewfs-1.1/workspaces
which uses a postgis database, not an H2 one... so if the PostGIS
database of the citewfs-1.1 configuration is not up and running, boom.
And if it is, well, you're testing against PostGIS, not against H2.
Btw, I'm a bit surprised the CITE instructions do not tell people to
use PostGIS for everything WFS... I guess the rationale is that the
WFS 1.0 tests cover PostGIS enough?
Andrea Aime
using the
wfs1.1.0
Hmmm... strange. I have no idea why it would be pointing there... I wonder if that happened during the switch over to relative externals.
Well when we did the initial wfs 1.1 compliance postgis was not around for jdbc-ng so I decided to stick with h2. But yeah now that postgis is in and we have a verified configuration we should update the docs to use it.
Justin Deoliveira
