"To check out the test sources an account on the OGG portal is required. If
you do not have one ask on the developer list for someone to check out the
tests for you."
I think that is the same bundle that Rini mentioned in our internal Jira (SISS-317). Look in the email from Justin from November 2009, which contains: http://files.opengeo.org/tests.zip
I think these are the droids you are looking for.
Kind regards,
Ben.
On 13/05/10 12:05, VT@anonymised.com wrote:
Hiya everyone,
I need the legacy file and test source to perform the CITE test for
GeoServer 2.0.2 release. I am following the instructions from
tests for you."
Thank you
Ben Caradoc-Davies <Ben.Caradoc-Davies@anonymised.com>
Software Engineering Team Leader
CSIRO Earth Science and Resource Engineering
Australian Resources Research Centre
