Hi list,
I would like to launch the test suite included in geoserver :
src/community/cite
i got the last sources from trunk/master
But when i try to mvn clean install i have some errors :
jar:file:/home/fgravin/.m2/repository/org/apache/maven/plugins/maven-antrun-plugin/1.6/maven-antrun-plugin-1.6.jar!/org/apache/maven/ant/tasks/antlib.xml:24: The following error occurred while executing this line:
jar:file:/home/fgravin/.m2/repository/org/apache/ant/ant/1.8.1/ant-1.8.1.jar!/org/apache/tools/ant/antlib.xml:37: Could not create task or type of type: componentdef.
i have ant 1.8.2 … maybe there is a conflict version
i tried to edit cite/pom.xml and change maven-antrun-plugin version but couldnt make it work.
Thanks for help
Florent Gravin
CampToCamp - Chambéry
0479444492
Hi Florent,
That cite community module is obsolete, i should really remove it from our repository. Instead you can use a secondary little project i set up here:
https://github.com/jdeolive/geoserver-cite-tools
Same idea, but more up to date and works with the latest versions of the tests for services that GeoServer implements.
Let me know if you have any questions.
-Justin
On Fri, Jul 13, 2012 at 8:39 AM, Florent Gravin <florent.gravin@anonymised.com> wrote:
Hi list,
src/community/cite
Thanks for help
Florent Gravin
0479444492
Live Security Virtual Conference
Exclusive live event will cover all the ways today’s security and
threat landscape has changed and how IT managers can respond. Discussions
will include endpoint security, mobile security and the latest in malware
threats. http://www.accelacomm.com/jaw/sfrnl04242012/114/50122263/
Geoserver-devel mailing list
Justin Deoliveira
OpenGeo - http://opengeo.org
I also ran into issues following the documentation (http://docs.geoserver.org/latest/en/developer/cite-test-guide/index.html). That page should be either updated to work with the source or removed along with the source as suggested. I ended up using Justin's project and it worked great. Thanks for that!
Michael
On 07/13/2012 07:43 AM, Justin Deoliveira wrote:
Hi Florent,
-Justin
On Fri, Jul 13, 2012 at 8:39 AM, Florent Gravin <florent.gravin@anonymised.com <mailto:florent.gravin@anonymised.com>> wrote:
Hi list,
src/community/cite
i have ant 1.8.2 ... maybe there is a conflict version
Thanks for help
-- Florent Gravin
0479444492
Exclusive live event will cover all the ways today's security and
Discussions
malware
<mailto:Geoserver-devel@lists.sourceforge.net>
Justin Deoliveira
Hey guys,
Just updated the cite test guide and removed the community module. Docs should be updated shortly.
-Justin
On Fri, Jul 13, 2012 at 3:14 PM, Michael Romero <mromero@anonymised.com> wrote:
I also ran into issues following the documentation (http://docs.geoserver.org/latest/en/developer/cite-test-guide/index.html). That page should be either updated to work with the source or removed along with the source as suggested. I ended up using Justin’s project and it worked great. Thanks for that!
Michael
Hi Florent,
-Justin
Hi list,
src/community/cite
Thanks for help
Florent Gravin
0479444492
Justin Deoliveira
threats. [http://www.accelacomm.com/jaw/sfrnl04242012/114/50122263/](http://www.accelacomm.com/jaw/sfrnl04242012/114/50122263/)
[Geoserver-devel@lists.sourceforge.net](mailto:Geoserver-devel@lists.sourceforge.net)
[https://lists.sourceforge.net/lists/listinfo/geoserver-devel](https://lists.sourceforge.net/lists/listinfo/geoserver-devel)
Justin Deoliveira
On Tue, Jul 17, 2012 at 5:09 PM, Justin Deoliveira <jdeolive@anonymised.com> wrote:
Hey guys,
Cool, thanks for doing that
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
fax: +39 0584 962313
mob: +39 339 8844549
Yes, that was very helpful thanks! We are in the process of adding jobs in our Jenkins instance to run the cite tests against our GeoServer, similar to the OpenGeo Jenkins.
Michael
On 07/17/2012 08:56 AM, Andrea Aime wrote:
On Tue, Jul 17, 2012 at 5:09 PM, Justin Deoliveira <jdeolive@anonymised.com <mailto:jdeolive@anonymised.com>> wrote:
Hey guys,
Ing. Andrea Aime
@geowolf
Technical Lead
[This was the cite tests thread]
Oh, we should compare notes. We are not running cite tests but are running jdbc tests and app-schema online tests against postgis and oracle.
I am in the process of writing it up (so it will be a mess for the next six hours or so):
https://www.seegrid.csiro.au/wiki/Infosrvices/JenkinsGeoserverMaster
https://www.seegrid.csiro.au/wiki/Infosrvices/JenkinsGeoserverMasterTechnicalNotes
There are many ways to configure Jenkins (and I am a Jenkins n00b). This one is a pipeline of jobs locked to a single executor with fixed workspace names, ordered with the build priority plugin, no Jenkins artifact archival (everything kept in the slave workspaces). The docs include a slave startup script for Debian 6 squeeze.
Our coverage is Oracle JDK 6 64-bit. I know we have had expressions of interest from list members wanting OpenJDK 7 CI coverage. More Jenkins = more good.
Kind regards,
Ben Caradoc-Davies <Ben.Caradoc-Davies@anonymised.com>
Software Engineer
CSIRO Earth Science and Resource Engineering
Australian Resources Research Centre
On Wed, Jul 18, 2012 at 2:23 AM, Michael Romero <mromero@anonymised.com> wrote:
Interesting. Will it be something closed, or one that will be somehow shared with the community like OpenGeo one?
What operating system are you going to run the tests on?
Ing. Andrea Aime
@geowolf
Technical Lead
On Tue, Jul 17, 2012 at 8:46 PM, Ben Caradoc-Davies <Ben.Caradoc-Davies@anonymised.com> wrote:
Nice, actually I just recently set up our build bot to do the same. Any chance you are seeing the same failure as located here:
http://hudson.opengeo.org/hudson/view/geotools/job/geotools-8.x-jdbc/
Definitely more jenkins == good. A while back I had mentioned that I wanted to actually throw most of our job configuration/scripts in version control but never really got around to it. If folks are interested in that and using it for another hudson instance i can try to start that movement again.
I also pretty interested to try out hudsons/jenkins multi-node feature as well. Anyone have any experience with it?
Kind regards,
Ben Caradoc-Davies Ben.Caradoc-Davies@anonymised.com
Software Engineer
Justin Deoliveira
On 18/07/12 18:49, Justin Deoliveira wrote:
Nice
Thanks. I still know my Jenkins setup has problems; I will keep on working on it as time permits.
Yes, I created a Jira issue for this failure on Tuesday, I see it on both Oracle 11g and PostreSQL 8.4 in Maven. I have also reproduced it in Eclipse against PostgreSQL 9.0.8.
Intermittent JDBCJoinTest failures
https://jira.codehaus.org/browse/GEOT-4204
Kind regards,
Software Engineer
On Wed, Jul 18, 2012 at 7:43 PM, Ben Caradoc-Davies <Ben.Caradoc-Davies@anonymised.com> wrote:
Nice
Intermittent indeed… the build seems to be back to fixed… for now
Kind regards,
Software Engineer
Justin Deoliveira
Unfortunately everything we are doing is protected behind government certificates. Also we are testing the layers we have for compliance rather than GeoServer itself so I don't know how useful it would be to the community. We are testing on CentOS.
Michael
I think I am even more of a n00b than you We have a CI server that builds/deploys our software and updates our layers in GeoServer about every 6 hours. We are in the (early) process of running integration tests against our GeoServer instance and what better way to test compliance then the CITE tests.
Justin: that would be great if the Jenkins confi/scripts were version controlled. It might encourage more people to stand up instances (jenkins.equals(good)). I kind of reverse engineered a script to mark the job as a failure from the output of the OpenGeo jobs.
Michael
