just noticed this failure:
Testing getmap:each-format (wms-1.3.0/d3717e372_1/d1097e46_1/d1097e214_17)...
[exec] Assertion: For format "image/vnd.jpeg-png", when the FORMAT parameter is set to that format, the MIME type of the response matches that format.
[exec] Test getmap:each-format Failed
Eh well… that thing returns either jpeg or png, but never its exact MIME, doing so would likely make the format useless in browsers (they don’t know what image/vnd.jpeg-png is)
Options coming to mind:
Remove the format from the list when the WMS “strict CITE compliance” setting is enabled (bye bye format)
Make it return its own MIME type instead of image/png or image/jpeg when the WMS “strict CITE compliance” setting is enabled (bye bye browsers, which are the primary users)
As an alternative, modify the CITE data dir to blacklist that format using the WMS “Allowed MIME types for a GetMap request” settings (works, but if someone tries to run CITE tests on their own they might not know about this option… documentation could be added though)
I’d go for 3… other opinions anyone?
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
