[Geoserver-devel] CITE tests issue
I am trying to run the CITE tests and I seem to have exactly the same issue as described here with a lot of tests
http://jira.codehaus.org/browse/GEOS-3970
(was resolved)
Something with encoding? On Victor’s advise I added -Dfile.encoding=UTF-8 to VM, but didn’t help.
Niels Charlier
Software Engineer
CSIRO Earth Science and Resource Engineering
Phone: +61 8 6436 8914
Australian Resources Research Centre
26 Dick Perry Avenue, Kensington WA 6151
I am not sure exactly why it happens but when the directory is created via svn it gets encoded slightly differently and that appears to throw things off. Sorry I don’t have a better explanation… i did not spend much time looking into it.
However, if you copy or rename the directory under workspaces/sf/sf manually it should work ok:
mv EntitéGénérique tmp
mv tmp EntitéGénérique
That fixed it on the build server.
-Justin
(was resolved)
Niels Charlier
Software Engineer
Beautiful is writing same markup. Internet Explorer 9 supports
standards for HTML5, CSS3, SVG 1.1, ECMAScript5, and DOM L2 & L3.
Spend less time writing and rewriting code and more time creating great
experiences on the web. Be a part of the beta today.
http://p.sf.net/sfu/beautyoftheweb
Geotools-devel mailing list
Geotools-devel@anonymised.coms.sourceforge.net
https://lists.sourceforge.net/lists/listinfo/geotools-devel
Justin Deoliveira
OpenGeo - http://opengeo.org
I think it’s the character encoding of the terminal / ssh client when you do the checkout. Make sure it’s all UTF-8.
-Arne
