I'm having rather poor luck with the new cite engine, though so far it seems to be configuration snafus. I've gotten many working, but I'm now getting a batch of failures with both WFS-1.1.0 and WFS-1.0.0. I'm hoping someone will recognise some of my error logs (attached) and suggest what I've done wrong.
FYI: I was able to get through all the cite tests a week ago (when Justin was unfortunate enough to be sitting behind me), so I'm fairly convinced the issues are in my configuration of the tests, not in GeoServer or GeoTools.
WFS-1.1.0:
Test wfs:wfs-1.1.0-Basic-DescribeFeatureType-tc2.1 (wfs-1.1.0/d1e32742_1/d1e717_1/d1e24425_1/d1e4692_1)
Assertion: The Content-Type of all POST KVP-encoded request entities must be 'application/x-www-form-urlencoded'.
Request d1e4782_1:
Method: post
URL: http://localhost:8080/geoserver/wfs?
Body: service=WFS&version=1.1.0&request=DescribeFeatureType&typename=sf:PrimitiveGeoFeature&namespace=xmlns(sf=http://cite.opengeospatial.org/gmlsf)
Error in call to extension function {public org.w3c.dom.NodeList com.occamlab.te.TECore.request(org.w3c.dom.Document,java.lang.String) throws java.lang.Throwable}: Exception in extension function java.lang.Exception: Error invoking parser {http://teamengine.sourceforge.net/parsers\}XMLValidatingParser.XMLSchema
org.xml.sax.SAXParseException: src-resolve: Cannot resolve the name 'xml:lang' to a(n) 'attribute declaration' component.
Result: Failed
WFS-1.0.0:
Assertion: When a wfs:Transaction request is made to Update a locked feature using the lockId the feature was locked with, the result document be be a wfs:WFS_TransactionResponse with a wfs:Status of wfs:SUCCESS.
Failed to compile stylesheet. 1 error detected.
Result: Failed
WFS-1.1.0:
Request d1e4782_1:
Method: post
Result: Failed
Hmmm... I have seen this error before, and the cause was because I was the machine i was running the tests on was offline, so the internal validator was not able to grab the online xml.xsd schema, in which xml:lang is defined.
WFS-1.0.0:
Result: Failed
This one has me at a loss...
Let Crystal Reports handle the reporting - Free Crystal Reports 2008 30-Day trial. Simplify your report design, integration and deployment - and focus on what you do best, core application coding. Discover what's new with Crystal Reports now. http://p.sf.net/sfu/bobj-july
Geoserver-devel mailing list
Justin Deoliveira
OpenGeo - http://opengeo.org
Justin Deoliveira ha scritto:
>> WFS-1.0.0:
Result: Failed
Random shot in the dark: has the database been cleaned between runs?
Sometimes the WFS-T tests do fail because of previous tests run left
the database in an unexpected state
Andrea Aime
<snip>
WFS-1.0.0:
Result: Failed
Ok, I dug a bit deeper and indeed there is an error in the test cases. Quite a few actually. I have patched the tests and put a new test archive up here:
http://files.opengeo.org/cite_test_scripts.zip
Give those a go and hopefully all will be smooth.
I also forwarded the patched tests to the engine maintainer.
-Justin
Justin Deoliveira
Justin Deoliveira wrote:
<snip>
WFS-1.0.0:
Result: Failed
-Justin
Thank you Justin. You're quickly becoming my new hero.
I'm down to the two wfs-1.1.0 errors that look like connectivity problems (below). I'm online, with many an interweb pingable. I take it these are schemas it's trying to look up? Does anybody know where these live?
Request d1e4782_1:
Method: post
Result: Failed
Assertion: A valid namespace binding expressed by the namespace parameter in a KVP string shall conform to the syntax specified in subclause 14.4.
Request d1e3809_1:
Method: get
URL: http://localhost:8080/geoserver/wfs?&service=WFS&version=1.1.0&request=DescribeFeatureType&typename=sf:PrimitiveGeoFeature&namespace=xmlns(sf=http://cite.opengeospatial.org/gmlsf)
org.xml.sax.SAXParseException: s4s-elt-invalid-content.1: The content of '#AnonType_schema' is invalid. Element 'attribute' is invalid, misplaced, or occurs too often.
Result: Failed
