the 2.8.x and master branch CITE tests have been all failing for the
past couple of days.
As far as I can see, GeoServer just fails to deploy, e.g., this is what
the tool checking if it’s up gets at the end:
Pinging GeoServer at [http://localhost:11010/geoserver](http://localhost:11010/geoserver)
+ curl -G [http://localhost:11010/geoserver](http://localhost:11010/geoserver)
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0
100 1296 100 1296 0 0 22234 0 --:--:-- --:--:-- --:--:-- 22736
<html>
<head>
<meta http-equiv="Content-Type" content="text/html; charset=ISO-8859-1"/>
<title>Error 404 NOT_FOUND</title>
</head>
<body>
<h2>HTTP ERROR: 404</h2><pre>NOT_FOUND</pre>
<p>RequestURI=/geoserver</p>
<p><i><small><a href="[http://jetty.mortbay.org](http://jetty.mortbay.org)">Powered by jetty://</a></small></i></p>
And of course the test fails… it’s just that looking at the workspace from the
UI I cannot see any GeoServer logs at all, and if I get a nightly build and start it up,
it deploys without any issue
Has anyone a clue about what’s going on there? The 2.7.x CITE builds are apparently working fine
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
