even the wfs 1.0 tests arent' passing on the new engine,
thought all failures are on the DescribeFeatueType call.
Not sure what the failure is thought, the error message
is not very informative. Justin, any idea?
If you log in with the geoserver account, it's 1.6.x-aa-wfs-1.0.0.
Sure... I will try to run the tests this morning and figure out what is
going on.
Andrea Aime wrote:
This SF.net email is sponsored by DB2 Express
Download DB2 Express C - the FREE version of DB2 express and take
control of your XML. No limits. Just data. Click to get it now.
http://sourceforge.net/powerbar/db2/
Geoserver-devel mailing list
!DSPAM:4007,468a5199209753362379201!
Justin Deoliveira
The Open Planning Project
http://topp.openplans.org
It appears the DescribeFeatureTypes on the engine are flawed. I
validated the resulting schema in every way possible and no problems
with it... and the tests all pass in the old engine. I am going to bring
this up on the cite list.
Andrea Aime wrote:
Justin Deoliveira
Test all pass? I had 7 transaction related failures yesterday
in the old test? Maybe I should rerun it...
Justin,
I understand this is a old thread. But just curious whether you got
GeoServer pass TEAM Engine test. If so, can I simply follow CITE test
tutorial to run TEAM Engine test (of course I need change the test site)?
Many thanks
going on.
Andrea Aime wrote:
Justin Deoliveira
View this message in context: http://www.nabble.com/Cite-wfs-1.0-on-new-engine-not-passing-tp11412360p22855269.html
Sent from the GeoServer - Dev mailing list archive at Nabble.com.
Yes GeoServer passes cite tests with teamengine, but only specific versions of it, and only with specific data stores in the back end.
For info about how to build the engine and tests:
http://svn.codehaus.org/geoserver/trunk/src/community/cite/README.txt
And about how to set up and configure geoserver:
http://gridlock.openplans.org/geoserver/1.7.x/doc/developer/cite-test-guide/index.html
Hope that helps. Please let us know if you have any more questions.
-Justin
LionPSU wrote:
Justin,
Many thanks
going on.
Andrea Aime wrote:
Justin Deoliveira
Justin Deoliveira
OpenGeo - http://opengeo.org
