Torben,
CITE WFS 1.1 tests have been failing on all branches for about 7 days. Looking at master, the failures started with this geoserver-master-nightly build (CITE tests run from nightly builds):
http://ares.boundlessgeo.com/jenkins/view/geoserver/job/geoserver-master-nightly/1410/changes
The only relevant change seems to be:
[GEOS-8117] Improve support for null service/version/request in KvpUtils
https://github.com/geoserver/geoserver/pull/2289
https://osgeo-org.atlassian.net/browse/GEOS-8117
CITE tests are old and seem to expect //wfs:WFS_Capabilities/@version='1.1.0' if version is not specified because that was the highest version when the CITE tests were published. From:
http://ares.boundlessgeo.com/jenkins/view/testing-cite/job/cite-wfs-1.1/1317/consoleText
First failure:
[exec] Testing wfs:wfs-1.1.0-Basic-GetCapabilities-tc13.3 (wfs-1.1.0/d41e34700_1/d41e749_1/d41e24740_1/d41e894_1)...
[exec] Assertion: A KVP-encoded GetCapabilities request shall include the following query parameters: service=WxS request=GetCapabilities, where WxS is a mnemonic label for a service type. See Table 2 for definitions of optional query parameters.
[exec] Testing ctl:assert-xpath (wfs-1.1.0/d41e34700_1/d41e749_1/d41e24740_1/d41e894_1/d41e2445_1)...
[exec] Assertion:
[exec] Evaluates the given XPath expression against the input document and
[exec] returns a boolean result according to the XPath specification (see
[exec] http://www.w3.org/TR/xpath#section-Boolean-Functions).
[exec]
[exec] The expression '//wfs:WFS_Capabilities/@version='1.1.0'' is false.
[exec] Test ctl:assert-xpath Failed
[exec] Test wfs:wfs-1.1.0-Basic-GetCapabilities-tc13.3 Failed (Inherited failure)
Second failure:
[exec] Testing wfs:wfs-1.1.0-Basic-GetCapabilities-tc14.1 (wfs-1.1.0/d41e34700_1/d41e749_1/d41e24740_1/d41e899_1)...
[exec] Assertion: If AcceptVersion is not specified, the service must respond with highest supported version.
[exec] Testing ctl:assert-xpath (wfs-1.1.0/d41e34700_1/d41e749_1/d41e24740_1/d41e899_1/d41e2519_1)...
[exec] Assertion:
[exec]
[exec] Test wfs:wfs-1.1.0-Basic-GetCapabilities-tc14.1 Failed (Inherited failure)
Kind regards,
Ben Caradoc-Davies <ben@anonymised.com>
Director
Transient Software Limited <http://transient.nz/>
New Zealand
