[Geoserver-devel] Clarification/change on the release policy
today we stuck a bug, scheduled for fixing in 1.4.0rc2, that
needs a geotools change.
It's quite evident that requiring a geotools release for each
geoserver milestone or RC simply does not work, we almost had
to re-release 2.2.1 two days later, and now we would need another
one. This is clearly unacceptable, given the effort required
to release geotools (at least half a day).
The only viable alternative is, according to me, to depend on snapshots for milestones and RCs, and release geotools only for geoserver final releases.
sounds completely reasonable to me.
+1
Gabriel
On Thursday 26 October 2006 16:07, Andrea Aime wrote:
releases.
Using Tomcat but need to do more? Need to support web services, security?
Get stuff done quickly with pre-integrated technology to make your job
easier Download IBM WebSphere Application Server v.1.0.1 based on Apache
Geronimo
http://sel.as-us.falkag.net/sel?cmd=lnk&kid=120709&bid=263057&dat=121642
Geoserver-devel mailing list
Gabriel Roldán (groldan@anonymised.com)
Axios Engineering (http://www.axios.es)
Tel. +34 944 41 63 84
Fax. +34 944 41 64 90
+1 here. Perhaps we could say something like the first Release Candidate should have a GeoTools release, or at least something to encourage GeoTools releases. But we can't go through that whole process for every minor fix.
Chris
+1
Gabriel
releases.
Geronimo
Chris Holmes
The Open Planning Project
http://topp.openplans.org
I will update the GSIP to reflect this.
Brent Owens
(The Open Planning Project)
Chris
+1
Gabriel
releases.
Geronimo
Get stuff done quickly with pre-integrated technology to make your job easier
Download IBM WebSphere Application Server v.1.0.1 based on Apache Geronimo
+1
I'd suggest that we ought to however _aim_ for a geotools release for each major milestone, but not for subsequent maintenance releases. I think the release process will focus the minds on the quality of the build a little better, and Geoserver releases against it should be seen as part of the testing process for getting Geotools through the release cycle.
Rob A
+1
Gabriel
releases.
Geronimo
That can work Andrea, and is a good suggestion - I believe there is a mechanism for publishing snapshots to the repository? If we can document that process it would be good.
Jody
As far as I know there's something already publishing geotools
snapshots from 2.2.x branch on lists.refractions.net.
Don't know if it's a CruiseControl tool at Refractions, of
it's maybe a JesseControl, RichardControl or a CoryControl... :-p
Rob Atkinson ha scritto:
+1
Hmm... can you define major milestone?
Thinking about it, it seems reasonable to require that each geoserver
milestone/release candidate works against a geotools "stable" branch
(2.2.x, 2.3.x) as opposed to trunk, and that we push a real geotools
release for every geoserver "stable" release (so, not milestone nor RC).
And yes, indeed this means that we need a cruise control that pushes
that branch snapshots onto the maven repos.
