On Fri, Aug 5, 2016 at 9:56 PM, Gabriel Roldan <groldan@anonymised.com>
wrote:
In a nutshell:
- have /tmp/getotools-<version> and /tmp/geoserver-<version> directories
- run maven with mvn -Djava.io.tmpdir=/tmp/geotools|geoserver-<version>
- run rm -rf /tmp/geotools|geoserver-<version>/* in the post-build shell
script
Works for me.
and voilá.
Moreover, ares doesn't have it's /tmp in its own partition, and there's a
tmpfs (i.e. memory) mounted at /mnt/memtmp which we use to speed up the
geogig build (that is, running tests that do IO in a tmpfs). Would you guys
be interested in doing that too?
It might provide some benefit, but not all that much in geoserver where
most test resources (e.g., the data dirs) are created
inside "<module>/target" (and I believe that is valid for many, but not
all, geotools modules as well).
I guess that could be made parametric too to get a speedup, I'm just not
sure how well isolated the
tests would be for parallel builds (I believe they are using some sort of
UUID like mechanism to name them, but I might be wrong)
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
