in preparation for the 2.23-RC release, I was looking at
community and extension modules that could be dropped.
I’d suggest moving these modules down, from extension to community:
XLST. I have built that 10 years ago, has been sitting there quietly, mostly gathering dust, haven’t touched it since. I’d say it did not find interest in the community.
imagemap, originally maintained by Mauro Bartolomeoli. Mauro has not been active for a while (knock if you read this mail Mauro!) and image maps have been out of favor in front end development for a long while now.
Speaking of community modules instead, I’d suggest removing from the source tree the following:
WMS-EO (lack of use/interest)
SAML (anyone using it?)
OWS-Simulate (contributed by Justin some year ago, does it still have any use?)
NSG-WMTS profile (no traction)
WMTS-styles (part of a testbed, did not have follow up)
ogcapi/image (an experiment, did not have follow up)
ext-teradata (with the removal of the corresponding geotools code
importer-fgdb (not even in the community build)
Anything more? Or anything you’re still interested in keeping around with a minimum of care and feeding for the module?
This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
Has COG received enough real world use to be considered an extension. I have had customers using it for 6 months now; but I understand we try for a year in production.
There are still known issues with large COGs and something else with … what was it… masks I believe.
