Justin Deoliveira ha scritto:
I like the idea of having nicer urls, but I this proposed solution seems to get us only part of the way there. The given strategy gives us a nice url for the top level pages, but what pages linked from those? As far as I can tell the mount points don't seem to propagate down.
Nope, they do not, each page has to be mounted separately. Which would
mean we have to register in the app context something that performs
these registrations on a module per module basis.
I wonder if it makes sense to bridge this idea with some sort of custom url encoding strategy, which seems to be the way to do this sort of stuff in wicket. See IRequestTargetUrlCodingStrategy.
Some quick googling leads me also to this:
http://java.dzone.com/news/wicket-creating-restful-urls
Which I think could fit in quite well with the current UI.
I would like to see some sort of automatic mapping as well. Maybe
something based on a package + class name convention.
The code in the same ends up being:
MixedParamUrlCodingStrategy productURLS = new MixedParamUrlCodingStrategy(
"products",
ProductDetailPage.class,
new String{"id"}
mount(productURLS);
So in the end you have to mount the pages manually anyways it
would seem, the strategy makes sure to provide a nice rest-y
url.
I think it would be nice if we had a mechanism so that when
Wicket encounters a link as:
http://host:port/geoserver/p1/p2/p3/name
it automatically looks up for class:
org.geoserver.web.p1.p2.p3.namePage
without the need to mount it? No idea if it's possible at all,
I'll dig a little.
In any case, having nice rest-y URLs for entry points is nice.
It is extra work, but worthwile.
Mind, we'll end up with non rest-y URLs any time a non ajax
action is performed or when we go back to an edited page, the
usual hard to read link Wicket generates in that case is a path
in a server side data structure allowing to retrieve back a
specific page in a specific state (with certain contents and
certain components visible and so on).
As for demo pages, yes, I think we should try to adapt this for any sort of page. Probably MenuPageInfo and DemoLinkInfo should share a common super type "PageInfo". Also DemoLinkInfo should be renamed to DemoPageInfo for consistencies sake.
So this PageInfo registration could be the information used
to perform the mount-ing?
Andrea Aime
OpenGeo - http://opengeo.org
