In order to facilitate clustering, we are planning to get rid of ALL remaining file-based configurations in geoserver and move them to a db, like was already done for the catalog with jdbcconfig. Not entirely clear yet what "all" entails yet, but I'm doing some research and investigating different possible approaches and then come up with a realistic scope.
Currently we have the interface ResourceStore which forms the basis for retrieving configurations and data from the data directory. This interface assumes a directory structure. I think the least intrusive approach would be to emulate a directory structure in a relational database, with the files as blobs, and then create a different implementation of ResourceStore to access it. I'll call this plan (A).
Alternatively, we could create a whole new configuration API which allows a more structural and efficient usage of the relational database to store and retrieve configuration settings. I'll call this plan (B). This plan just seems way too big of a change to me.
Issues with plan (A):
* Although the Resource interface offers an inputstream and outputstream through its API, most code does not use these functions; but rather accesses the file system directly with FileInputStream and FileOutputStream. The ResourceLoader is often only used for one thing and that is to get paths from the data directory. This is the case for core code such as the security system, GWC, and extensions such as CSW and XSLT (and properly a lot more than I have found so far). Still, these modifications would still be far less than would be the case in plan (B).
* The data directory is not only used for settings but also for temporary files (for example WPS). It would perhaps be strange/undesirable/problematic if the database was used for this.
* What about configurations read from geotools. For example, the application schema extension is implemented in geotools, and the location of the app-schema specific config files are specified as a path from the store configuration. If there was a solution for that, perhaps an interesting side effect would be that even the data itself could be stored this way. For example, one could upload a shapefile through rest which would then be stored in the db.
Either way this seems like a huge change, that will need to a lot of discussion. Perhaps some people have a completely different and better idea. Any suggestions, opinions ... ?
clear yet what “all” entails yet, but I’m doing some research and
realistic scope.
implementation of ResourceStore to access it. I’ll call this plan (A).
to store and retrieve configuration settings. I’ll call this plan (B).
plan (B).
idea. Any suggestions, opinions … ?
Regards
Niels
Don’t Limit Your Business. Reach for the Cloud.
GigeNET’s Cloud Solutions provide you with the tools and support that
you need to offload your IT needs and focus on growing your business.
Configured For All Businesses. Start Your Cloud Today. https://www.gigenetcloud.com/
Ah okay I didn't know a JDBCResourceStore was already in development! I was only aware of the API in place that allows it.
Will need to talk to @Kevin about this then
Niels
On 09-07-15 03:05, Jody Garnett wrote:
Yep that is the design, see original proposal and talk to Kevin who started a JDBCresourceStore he should be able to share with you.
On a related not we can still hunt down some file use and change it to use inputstream for direct blob access.
On Wed, Jul 8, 2015 at 12:56 PM Niels Charlier <niels@anonymised.com <mailto:niels@anonymised.com>> wrote:
Hello,
a db,
realistic scope.
basis for
database
outputstream
plan (B).
a path
perhaps
rest
Regards
Niels
Don't Limit Your Business. Reach for the Cloud.
GigeNET's Cloud Solutions provide you with the tools and support that
Geoserver-devel mailing list
<mailto:Geoserver-devel@lists.sourceforge.net> https://lists.sourceforge.net/lists/listinfo/geoserver-devel
