Dear Geoserver developers:
Note that as the big code reorganization has just started, trunk will
be broken a couple of days, since I need to remotely moving files and
directories using 'svn move' with absolute urls in order to let svn keep
track of the changes. If I do now do that, and instead do the lot easier
local refactoring, svn will do an add and remove for each resource,
loosing resource history.
Gabriel.
GeoServer is up and running, las modifications:
got rid of geoserver.requests and .responses packages. Utility classes
sent to geoserver.util.
geoserver.util still needs some work, by now it is where things that do
not belong to more specifick packages are holded, but I now have to run
home.
next tasks: finish cleaning up util and start reorganizing action config
form and global.
test it if you can.
Gabriel.
Gabriel.
SF email is sponsored by - The IT Product Guide
Read honest & candid reviews on hundreds of IT Products from real users.
Discover which products truly live up to the hype. Start reading now.
http://ads.osdn.com/?ad_id=6595&alloc_id=14396&op=click
Geoserver-devel mailing list
