[Geoserver-devel] Commas in custom dimensions and getCapabilities
I’m trying to build a mosaic using a custom domain which contains special characters (commas, apostrophe, etc) in dimension values.
In my CROP dimension I have
1 Cereals
2 Oil, crops
3 Root
The result in the getCapabilities is:
Cereals,Oil,crops,Root
Which is exactly what the standard says but essentially it is wrong…
<<The extent string declares what value(s) along the Dimension axis are appropriate for the corresponding layer.
The extent string has the syntax shown in Table C.2.>>
Ref:
http://www.opengeospatial.org/standards/wms
To be correct it should be something like:
“Cereals”,“Cereals”,“Oil, crops”,“Root”
Anyhow this is not very close to the standard.
I’m considering adding quotes to all of my dimension values but this is probably not acceptable for all.
What do you think?
Carlo
Dott. Carlo Cancellieri
@cancellieric
Software Engineer
Via Poggio alle Viti 1187
mobile: +39 3371094494
On Fri, Oct 11, 2013 at 7:05 PM, carlo cancellieri <
carlo.cancellieri@anonymised.com> wrote:
I'm trying to build a mosaic using a custom domain which contains special
1 Cereals
2 Oil, crops
3 Root
<Dimension name="CROP"
default="Cereals"
units="">Cereals,Oil,crops,Root
</Dimension>
Which is exactly what the standard says but essentially it is wrong...
Ref:
default="Cereals"
units="">"Cereals","Cereals","Oil, crops","Root"
</Dimension>
I'm considering adding quotes to all of my dimension values but this is
Adding quotes around the dimension values will most likely break the wms
standard, and standard clients
will simply ignore them.
In other words, to a compliant standard, the above list defines the
following possible values:
"Cereals"
"Cereals"
"Oil
crops"
"Root"
ant then they will add to the GetMap request ...&DIM_CROP="Oil&...
Long story short, your use case places you out of the WMS standard reach,
and the solution will break
any standard client.
My suggestion: don't try to use human readable values for your dimensions,
use codes and have a lookup
table to turn them into human readable ones for your clients
information.
Ing. Andrea Aime
@geowolf
Technical Lead
mob: +39 339 8844549
On Fri, Oct 11, 2013 at 7:46 PM, Andrea Aime
Ah hem... "to a standard compliant client, the above list..."
information.
Ing. Andrea Aime
@geowolf
Technical Lead
