Hi All,
In talk with Justin about documentation in Portuguese, he talked that I needed to write to the list to request access to documentation in the SVN
I would like to request access to the SVN.
Best regards,
Fernando Quadro
Hi All,
Best regards,
Fernando Quadro
That is great Fernando!
The process for getting commit access involves creating a codhaus account and applying to join the geoserver project.
This is documented here:
http://docs.geoserver.org/2.0.x/en/developer/policies/comitting.html#community-commit-access
Once you have signed up let us know (include your codehaus username) and one of us will grant the request to join.
-Justin
On 2/10/10 6:17 PM, Fernando Quadro wrote:
Hi All,
I would like to request access to the SVN.Best regards,
Fernando Quadro------------------------------------------------------------------------------
SOLARIS 10 is the OS for Data Centers - provides features such as DTrace,
Predictive Self Healing and Award Winning ZFS. Get Solaris 10 NOW
http://p.sf.net/sfu/solaris-dev2dev_______________________________________________
Geoserver-devel mailing list
Justin Deoliveira
OpenGeo - http://opengeo.org
Justin,
My username in Codehaus is fernandoquadro
Best Regards,
Fernando Quadro
2010/2/10 Justin Deoliveira <jdeolive@anonymised.com>
account and applying to join the geoserver project.This is documented here:
one of us will grant the request to join.-Justin
Hi All,
Fernando Quadro
https://lists.sourceforge.net/lists/listinfo/geoserver-devel–
Justin Deoliveira
Hi Fernando,
Ok, i accepted the request so you now have commit access. Be mindful thought that this gives you only isolated commit access for documentation.
Also before you go forward all committees must sign the GeoServer contributor agreements which agrees to assign copyright for your work to TOPP.
You can download the form here:
http://geoserver.org/download/attachments/1278277/assignment_agreement.pdf?version=4
If you can fill that out at your earliest convenience that would be great.
Other then that the documentation is divided up by language:
http://svn.codehaus.org/geoserver/trunk/doc/
You will see "en" and "es". I suggest you create a new directory named "pt_BR" and work under there.
Enjoy
-Justin
On 2/11/10 1:28 PM, Fernando Quadro wrote:
Justin,
My username in Codehaus is *fernandoquadro*
*Best Regards,*
*Fernando Quadro
<mailto:jdeolive@anonymised.com>>That is great Fernando!
> Hi All,
that I
the SVN
> Best regards,
> Fernando Quadro
DTrace,
<mailto:Geoserver-devel@lists.sourceforge.net>
> https://lists.sourceforge.net/lists/listinfo/geoserver-devel--
Justin Deoliveira
Enterprise support for open source geospatial.------------------------------------------------------------------------------
DTrace,
https://lists.sourceforge.net/lists/listinfo/geoserver-devel------------------------------------------------------------------------------
Justin Deoliveira
