[Geoserver-devel] Commit error
Hi list,
I’ve been trying to commit to Geoserver with no joy.
I can run update and diff though, and I haven’t changed my password or anything.
I tried committing from subclipse, command line, and tortoise svn, but it’s all the same.
Error: Commit failed (details follow):
Error: Server sent unexpected return value (403 Forbidden) in response to MKACTIVITY
Error: request for ‘/geoserver/!svn/act/b3af7fb2-6102-4347-b285-2c7b608474bd’
Is there something going on with the server, or is it only me?
Thank’s
Rini
Rini.Angreani@anonymised.com ha scritto:
Hi list,
I've been trying to commit to Geoserver with no joy. I can run update and diff though, and I haven't changed my password or anything. I tried committing from subclipse, command line, and tortoise svn, but it's all the same.
Error: Commit failed (details follow): Error: Server sent unexpected return value (403 Forbidden) in response to MKACTIVITY Error: request for '/geoserver/!svn/act/b3af7fb2-6102-4347-b285-2c7b608474bd'
Odd, I just made a test commit and it worked fine.
Looked on xircles and you are still listed as a GeoServer developer
too... so quite odd indeed.
Maybe it was a temporary problem? Can anyone else try out?
Andrea Aime
OpenGeo - http://opengeo.org
This is the error I get everytime I forget the S in httpS://svn.codehaus.org/.
The following command should fix it (make sure to get the spelling right, as it doesn't actually check that the destination URL is an SVN repository or even exists.)
$ svn switch --relocate http://svn.codehaus.org/ https://svn.codehaus.org/
David Winslow
OpenGeo - http://opengeo.org/
Hi list,
anything.
it's all the same.
to MKACTIVITY
Error: request for
Hi David,
I did svn info, and it tells me that I'm using the right URL:
C:\src\GeoServer-trunk\src\extension\app-schema\app-schema-test\src\test\java\or
g\geoserver\test>svn info
Path: .
URL: https://svn.codehaus.org/geoserver/trunk/src/extension/app-schema/app-schem
a-test/src/test/java/org/geoserver/test
Repository Root: https://svn.codehaus.org/geoserver
Repository UUID: ef1d6e69-97e5-0310-af46-8a06194da32a
Revision: 14118
Node Kind: directory
Schedule: normal
Last Changed Author: RiniAngreani
Last Changed Rev: 14083
Last Changed Date: 2010-03-10 15:46:58 +0900 (Wed, 10 Mar 2010)
Maybe I'll log an issue with Codehaus like Andrea suggested.
Thank's!
Rini
-----Original Message-----
From: David Winslow [mailto:dwinslow@anonymised.com]
Sent: Wednesday, 31 March 2010 10:28 PM
To: Andrea Aime
Cc: Angreani, Rini (CESRE, Kensington); geoserver-devel@anonymised.comet
Subject: Re: [Geoserver-devel] Commit error
David Winslow
Hi list,
anything.
it's all the same.
to MKACTIVITY
Error: request for
Just letting everyone knows in case some of you also have capitals in your username. It works for me.
Ben Walding commented on HAUS-1932:
Can you try with an all lowercase username - riniangreani
We changed the internals of authentication and this might be affecting you.
Rini
Sent: Wednesday, 31 March 2010 3:31 PM
To: Angreani, Rini (CESRE, Kensington)
Cc: geoserver-devel@lists.sourceforge.net
Hi list,
anything.
it's all the same.
to MKACTIVITY
Error: request for
Andrea Aime
