I’ve done some research for a uDig user. For Geoserver 1.6.3 uDig can’t add new features to a postgis via the WFS-T protocol. I’ve tested 1.5.4 and it work fine. The problem seems to be an xml parsing problem.
Seems the same problem occurs when editing shapefiles.
I notice that there aren’t default values for the category attribute that may have something to do with the problem.
Here’s the request and the stack trace for adding a feature to streams, let me know if you want the debug level higher. But this is really easy to reproduce. Just add a new feature with uDig and commit:
<sf:streams fid=“newsf:streams.9223372036854775807”>
sf:the_geom
<gml:MultiLineString srsName=“EPSG:26713”>
gml:lineStringMember
gml:LineString
<gml:coordinates decimal=“.” cs=“,”
ts=" ">
608364.9454970448,4923977.149388677
607848.5573049984,4923262.150353537
609119.6667008048,4922586.873487014
611026.3307945146,4923540.20553387
</gml:coordinates>
</gml:LineString>
</gml:lineStringMember>
</gml:MultiLineString>
</sf:the_geom>
sf:cat</sf:cat>
</sf:streams>
15 Apr 07:59:55 TRACE [org.geotools.xml] - startElement(http://www.opengis.net/wfs,Insert,Insert
15 Apr 07:59:55 TRACE [org.geotools.xml] - startElement(http://www.openplans.org/spearfish,streams,sf:streams
15 Apr 07:59:55 TRACE [org.geotools.xml] - startElement(http://www.openplans.org/spearfish,the_geom,sf:the_geom
15 Apr 07:59:55 TRACE [org.geotools.xml] - startElement(http://www.opengis.net/gml,MultiLineString,gml:MultiLineString
15 Apr 07:59:55 TRACE [org.geotools.xml] - startElement(http://www.opengis.net/gml,lineStringMember,gml:lineStringMember
15 Apr 07:59:55 TRACE [org.geotools.xml] - startElement(http://www.opengis.net/gml,LineString,gml:LineString
15 Apr 07:59:55 TRACE [org.geotools.xml] - startElement(http://www.opengis.net/gml,coordinates,gml:coordinates
15 Apr 07:59:55 TRACE [org.geotools.xml] - startElement(http://www.openplans.org/spearfish,cat,sf:cat
15 Apr 07:59:55 WARN [org.geoserver.ows] -
java.lang.RuntimeException: Parsing failed for cat: java.lang.StringIndexOutOfBoundsException: String index out of range: 0
at org.geotools.xml.impl.ParseExecutor.visit(ParseExecutor.java:142)
at org.geotools.xml.impl.BindingWalker$BindingExecutionChain.execute(BindingWalker.java:197)
at org.geotools.xml.impl.BindingWalker.walk(BindingWalker.java:163)
at org.geotools.xml.impl.ElementHandlerImpl.endElement(ElementHandlerImpl.java:222)
at org.geotools.xml.impl.ParserHandler.endElement(ParserHandler.java:499)
at org.apache.xerces.parsers.AbstractSAXParser.endElement(Unknown Source)
at org.apache.xerces.impl.XMLNSDocumentScannerImpl.scanEndElement(Unknown Source)
at org.apache.xerces.impl.XMLDocumentFragmentScannerImpl$FragmentContentDispatcher.dispatch(Unknown Source)
at org.apache.xerces.impl.XMLDocumentFragmentScannerImpl.scanDocument(Unknown Source)
at org.apache.xerces.parsers.XML11Configuration.parse(Unknown Source)
at org.apache.xerces.parsers.XMLParser.parse(Unknown Source)
at org.apache.xerces.parsers.AbstractSAXParser.parse(Unknown Source)
at org.geotools.xml.Parser.parse(Parser.java:185)
at org.geotools.xml.Parser.parse(Parser.java:164)
at org.geoserver.wfs.xml.v1_0_0.WfsXmlReader.read(WfsXmlReader.java:60)
at org.geoserver.ows.Dispatcher.parseRequestXML(Dispatcher.java:1072)
at org.geoserver.ows.Dispatcher.dispatch(Dispatcher.java:389)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:185)
at org.springframework.web.servlet.mvc.AbstractController.handleRequest(AbstractController.java:139)
at org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handle(SimpleControllerHandlerAdapter.java:44)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:684)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:625)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:392)
at org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:357)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:709)
at org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder.java:459)
at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1054)
at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:108)
at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1045)
at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:69)
at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:41)
at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:264)
at org.acegisecurity.intercept.web.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:107)
at org.acegisecurity.intercept.web.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:72)
at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:274)
at org.acegisecurity.ui.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:110)
at org.acegisecurity.providers.anonymous.AnonymousProcessingFilter.doFilter(AnonymousProcessingFilter.java:125)
at org.acegisecurity.ui.basicauth.BasicProcessingFilter.doFilter(BasicProcessingFilter.java:178)
at org.acegisecurity.context.HttpSessionContextIntegrationFilter.doFilter(HttpSessionContextIntegrationFilter.java:229)
at org.acegisecurity.util.FilterChainProxy.doFilter(FilterChainProxy.java:148)
at org.acegisecurity.util.FilterToBeanProxy.doFilter(FilterToBeanProxy.java:98)
at org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandler.java:358)
at org.mortbay.jetty.servlet.SessionHandler.handle(SessionHandler.java:231)
at org.mortbay.jetty.handler.ContextHandler.handle(ContextHandler.java:629)
at org.mortbay.jetty.webapp.WebAppContext.handle(WebAppContext.java:453)
at org.mortbay.jetty.handler.ContextHandlerCollection.handle(ContextHandlerCollection.java:149)
at org.mortbay.jetty.handler.HandlerCollection.handle(HandlerCollection.java:123)
at org.mortbay.jetty.handler.HandlerWrapper.handle(HandlerWrapper.java:141)
at org.mortbay.jetty.Server.handle(Server.java:303)
at org.mortbay.jetty.HttpConnection.handleRequest(HttpConnection.java:452)
at org.mortbay.jetty.HttpConnection$RequestHandler.content(HttpConnection.java:735)
at org.mortbay.jetty.HttpParser.parseNext(HttpParser.java:636)
at org.mortbay.jetty.HttpParser.parseAvailable(HttpParser.java:209)
at org.mortbay.jetty.HttpConnection.handle(HttpConnection.java:349)
at org.mortbay.io.nio.SelectChannelEndPoint.run(SelectChannelEndPoint.java:320)
at org.mortbay.thread.BoundedThreadPool$PoolThread.run(BoundedThreadPool.java:475)
Caused by: java.lang.StringIndexOutOfBoundsException: String index out of range: 0
at java.lang.String.charAt(String.java:558)
at org.geotools.xs.bindings.XSLongBinding.parse(XSLongBinding.java:90)
at org.geotools.xml.impl.ParseExecutor.visit(ParseExecutor.java:128)
… 64 more
