I tried running a mvn eclipse:eclipse in the community section of 1.5.x and got the following error.
There needs a dependancy version. I will add it and commit it.
C:\projects\geoserver\1.4.0-M1\community>mvn eclipse:eclipse
[INFO] Scanning for projects...
[ERROR] FATAL ERROR
[INFO] Error building POM (may not be this project's POM).
Project ID: org.geoserver:wfs2
POM Location: C:\projects\geoserver\1.4.0-M1\community\wfs\pom.xml
Validation Messages:
[0] 'dependencies.dependency.version' is missing for org.geotools:gt2-xml-gml2
[1] 'dependencies.dependency.version' is missing for org.geotools:gt2-xml-filter
[2] 'dependencies.dependency.version' is missing for org.eclipse.emf:common
[3] 'dependencies.dependency.version' is missing for org.geotools:gt2-xml
[4] 'dependencies.dependency.version' is missing for org.eclipse.xsd:xsd
[5] 'dependencies.dependency.version' is missing for org.eclipse.emf:ecore
Reason: Failed to validate POM
[INFO] Trace
org.apache.maven.reactor.MavenExecutionException: Failed to validate POM
at org.apache.maven.DefaultMaven.getProjects(DefaultMaven.java:365)
at org.apache.maven.DefaultMaven.doExecute(DefaultMaven.java:278)
at org.apache.maven.DefaultMaven.execute(DefaultMaven.java:115)
at org.apache.maven.cli.MavenCli.main(MavenCli.java:256)
at org.codehaus.classworlds.Launcher.launchEnhanced(Launcher.java:315)
at org.codehaus.classworlds.Launcher.launch(Launcher.java:255)
at org.codehaus.classworlds.Launcher.mainWithExitCode(Launcher.java:430)
at org.codehaus.classworlds.Launcher.main(Launcher.java:375)
Caused by: org.apache.maven.project.InvalidProjectModelException: Failed to validate POM
at org.apache.maven.project.DefaultMavenProjectBuilder.processProjectLogic(DefaultMavenProje
ctBuilder.java:926)
at org.apache.maven.project.DefaultMavenProjectBuilder.buildInternal(DefaultMavenProjectBuil
der.java:737)
at org.apache.maven.project.DefaultMavenProjectBuilder.buildFromSourceFileInternal(DefaultMa
venProjectBuilder.java:416)
at org.apache.maven.project.DefaultMavenProjectBuilder.build(DefaultMavenProjectBuilder.java
:192)
at org.apache.maven.DefaultMaven.getProject(DefaultMaven.java:515)
at org.apache.maven.DefaultMaven.collectProjects(DefaultMaven.java:447)
at org.apache.maven.DefaultMaven.collectProjects(DefaultMaven.java:491)
at org.apache.maven.DefaultMaven.getProjects(DefaultMaven.java:351)
... 11 more
[INFO] Total time: < 1 second
[INFO] Finished at: Thu Aug 31 09:32:12 CAT 2006
[INFO] Final Memory: 1M/3M
Kind Regards
Clint Lewis
