Hello,
I make a PR for fix https://osgeo-org.atlassian.net/browse/GEOS-9217and I need to have a commit access.
I send the contributor agreement at info@anonymised.com.
My GitHub profile is: https://github.com/dodeFrancois
Best regards
Hello,
Best regards
HI François,
you don’t need commit access to propose changes to GeoServer, the (appreciated) pull requests will
be merged by someone that has commit access once it is matching the contribution requirements.
Reviews of PRs are made on a volunteer basis, so that takes a bit of patience.
We recently added (right after your PR) a PR template that lists in a succinct way the requirements, they were already part of the
the contribution guidelines, but that’s a longer read that few look at.
Long story short, the quicker all PR requirements are met, the sooner the PR will be merged (but again, I’m stressing this,
there is not expected ETA because nobody is given working hours to review PRs).
Regards, Andrea Aime == GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
