[Geoserver-devel] Community module for prototype support of get/put/delete style on WMTS
for a pilot experiment I’d like to have a community module adding support for restful get/put/delete style
operations in WMTS (operations to be secured, similar to WFS Transaction).
The operations would have cross language support and behave in a different way than the SLD 1.0 GetStyle.
As said, it would be an experiment, not sure it will a future, but still good to have the code shared where
others can jump in and evolve/support later, rather than keep it in a private repo iMHO.
Worst case, it will be removed later down the road.
== GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
+1
let’s how it goes…
Simone Giannecchini.
GeoSolutions Director
  • sent from my mobile, apologies for brevity and typos-
+1 Any experimenting is welcome; I am curious as to what you have in mind (given our two examples of WMS GetStyle and the rest styles endpoint)I trust you can make some usability improvements.
Jody Garnett
Ah, as said it’s an experiment, I actually know the API is as implemented is problematic, but that’s the point, providing feedback of what works and what does not, so that
we don’t have to bend over backwards when a final API ends up in a standard. Hopefully some of the code might be reusable for later, if anything, a couple of
bug fixes came out of it :smiley:
