Are there any current efforts to implement quantized-mesh-1.0 output format? Has there been any interest in it?
Jason Newmoyer
Newmoyer Geospatial Solutions
843.606.0424
jason@anonymised.com
Jason Newmoyer
843.606.0424
To save others googling the URL should be https://cesiumjs.org/data-and-assets/terrain/formats/quantized-mesh-1.0.html
It looks interesting but I don’t know if anyone is planning an implementation.
Ian
Jason Newmoyer
843.606.0424
Geoserver-devel mailing list
Geoserver-devel@anonymised.com.366…sourceforge.net
Ian Turton
Ditto, I’m not aware of anyone working on it, but it would be cool to have one.
I do have some familiarity with it, what are you going to use to build the TIN model? Are you going to compute
it on the fly from raster data, with some hint about the current scale to generate an accurate, but not too accurate,
model?
Ian
Jason Newmoyer
843.606.0424
Geoserver-devel@anonymised.comrge.net
Ian Turton
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
Le jeudi 29 septembre 2016 10:13:12, Andrea Aime a écrit :
Ditto, I'm not aware of anyone working on it, but it would be cool to have
one.I do have some familiarity with it, what are you going to use to build the
model?
Support for quantized mesh was discussed in the Cesium Terrain Builder project
(C++, based on GDAL), but I'm not sure this went further. Anyway some
potentially useful references in this ticket:
Even
AndreaOn Thu, Sep 29, 2016 at 9:55 AM, Ian Turton <ijturton@anonymised.com> wrote:
> It looks interesting but I don't know if anyone is planning an
> implementation.
> Ian
>> Jason Newmoyer
>> 843.606.0424
>> _______________________________________________
>> Geoserver-devel@lists.sourceforge.net
>> https://lists.sourceforge.net/lists/listinfo/geoserver-devel
> Ian Turton
Spatialys - Geospatial professional services
http://www.spatialys.com
I did see plans for a (large) organisation to use Cesium with GeoServer.
I'm trying to find the detail, but it did involve an external plugin, perhaps
https://github.com/kaktus40/Cesium-GeoserverTerrainProvider or something like
that.
Brad
We have been prototyping a global terrain layer with Cesium using the GeoServerTerrainProvider (kaktus40) with 90m SRTM (CGIAR). Performance is not great compared to AGI’s public quantized-mesh data using CesiumTerrainProvider, which I believe relates to the fact that qm is multiresolution and by nature much smaller payloads and quicker to process by Cesium. Also, with GeoServerTerrainProvider you must make some assumptions about the level of detail (LOD) of your data. This will make things tricky when we get special collects like Lidar for specific areas and we ultimately want to mosaic that right into a single global elevation layer.
I see this as very similar to vector tiles in that 1) its a new general output format to implement for GeoServer, 2) integrates seamlessly with GeoWebCache and 3) to address Andrea’s question, it must be capable of on-the-fly simplification using scale hint. So, from raster source to TIN geometries to quantized-mesh on the fly.
It seems like we have some decent interest. And a few projects out there doing pieces and parts of this:
https://github.com/geo-data/cesium-terrain-builder
https://github.com/loicgasser/quantized-mesh-tile
I wonder if LibCTB implemented qm-1.0 and then exposed a method for us to generate just a single terrain file if that would save some work.
I’m trying to find the detail, but it did involve an external plugin, perhaps
that.Brad
Jason Newmoyer
843.606.0424
jason@anonymised.com…
