Dear all,
thanks to the contribution of MDA (https://mdacorporation.com), we are proposing a new security plugin for GeoServer able to authenticate against a Keycloak (https://www.keycloak.org/) instance.
This is a first version working under several conditions as explained in the documentation.
The module makes use of Keycloak Java Adapters in order to complete the handshake and allow the AuthenticationProvider to retrieve the Principal along with his Roles.
Currently this module has been developed among the Community Security Plugins already implementing OAuth2 Auth Providers also.
https://github.com/geoserver/geoserver/tree/master/src/community/security
http://docs.geoserver.org/stable/en/user/community/oauth2/index.html
Please see the related PRs for both for GeoServer 2.14.x and 3.13.x at
https://github.com/geoserver/geoserver/pull/2916
https://github.com/geoserver/geoserver/pull/2917
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
Via di Montramito 3/A - 55054 Massarosa (LU) - Italy
mob: +39 331 6233686
This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
