Hi Jose,
Request to join the project as a developer accepted. Welcome to the project!
For good measure it would be good (if you have not done so already) to review the community module guide.
http://docs.geoserver.org/stable/en/developer/policies/community-modules.html
And actually come to tink about it we already have a spatialite community module:
http://svn.codehaus.org/geoserver/trunk/src/community/spatialite/
You may wish to work there... or if you feel you would like a separate module that works too and we can integrate the two later.
-Justin
On Fri, May 13, 2011 at 2:14 PM, Jose Macchi <jmacchi@anonymised.com <mailto:jmacchi@anonymised.com>> wrote:
Justin, i have created account at codehaus and added required a
membership for geoserver.
Let me know if it's ok
Regards
Jose
Justin Deoliveira escribió:
This all sounds great Jose. A big +1 and I think better
sqlite/spatialite support will be something everyone welcomes.
As for getting commit access to create a community module you
can find the process here:
http://docs.geoserver.org/stable/en/developer/policies/comitting.html
But essentially it involves creating a codehaus account and
applying to join geoserver as a developer. Once you do that
let us know and we can approve the request.
-Justin
On Fri, May 13, 2011 at 10:32 AM, Jose Macchi
wrote:
Hello, I'm Jose from geotekne.com <http://geotekne.com>
<http://geotekne.com>. Currently
we are partners of OpenGeo,
and we would like to contribute at Geoserver with a new
community
module, so as we understand, we should ask for permission
on devlist.
The objective will be to get SQLite/SpatiaLite as a WFS
output format
for GeoServer.
See
http://docs.geoserver.org/stable/en/user/services/wfs/outputformats.html
The first part of this will involve cleaning up and testing
with SpatiaLite on a variety of platforms. The datastore is at
http://svn.osgeo.org/geotools/trunk/modules/plugin/jdbc/jdbc-spatialite/
We should test it on 32-bit and 64-bit Linux, OS X and Windows.
Then we expect to make an output format for GeoServer WFS.
It should
produce a full SQLite / Spatialite single file database. Done
properly
it should construct itself according to whatever WFS
parameters are
passed in, so could be multiple featureTypes, with different
properties,
of certain areas or attributes.
Let us know if it's ok, and if it's necesary to consider
some other
information/request on same "scope".
We would like your approval, and then....permissions to
commit on
community folder at svn
Regards
Jose
Achieve unprecedented app performance and reliability
What every C/C++ and Fortran developer should know.
Learn how Intel has extended the reach of its
next-generation tools
to help boost performance applications - inlcuding clusters.
http://p.sf.net/sfu/intel-dev2devmay
Geoserver-devel mailing list
<mailto:Geoserver-devel@lists.sourceforge.net>
<mailto:Geoserver-devel@lists.sourceforge.net>>
-- Justin Deoliveira
OpenGeo - http://opengeo.org
Justin Deoliveira
