As discussed in a previous thread I have modified the build to create artifacts for community modules.
Under the root community module there is now a release module that behaves like the regular community module but contains artifact descriptors for only those community modules that maintainers wish to publish as part of the nightly build.
To build the community artifacts:
1) Do a full build and engage the "communityRelease" profile
2) execute mvn assembly:attached from the root community folder
The artifacts end up in community/target/release
Hudson is publishing the results to:
http://gridlock.openplans.org/geoserver/trunk/community-latest/
http://gridlock.openplans.org/geoserver/2.0.x/community-latest/
Currently on the control flow module is being published. I am not sure if any
-Justin
Justin Deoliveira
OpenGeo - http://opengeo.org
