Dear developers,
I would like to create (and then maintain) two new community modules,
gs-gdal-wcs and gs-gdal-wps, whose purpose will be to leverage the
gdal_translate utility to support additional output formats in the WCS
and WPS services.
In practice, what I aim to do is to port the OGR extension to the raster
world:
- the conversion will be done by first dumping the coverage to disk in
GeoTIFF format and then invoking gdal_translate, passing the dumped
coverage as input
- users will be able to configure the GDAL formats they want to support
in a gdal_translate.xml file (almost identical to the ogr2ogr.xml
configuration file), where they can also customize the creation options
to pass to the gdal_translate command
- changes to the configuration file will be automatically detected by a
watcher and applied, no need to restart
The initial implementation is going to be very similar to the OGR
extension, with a significant amount of repeated code: perhaps at a
later time it could be advisable to factor out the shared logic into a
separate module both extensions would then be based off.
The WCS module is already in good shape and I will submit a PR soon.
Any feedback is appreciated!
Best regards,
Stefano Costa
Dott. Stefano Costa
Senior Software Engineer
Via Poggio alle Viti 1187
nel/i file/s allegato/i sono da considerarsi strettamente riservate.
Il loro utilizzo è consentito esclusivamente al destinatario del
messaggio, per le finalità indicate nel messaggio stesso. Qualora
riceviate questo messaggio senza esserne il destinatario, Vi preghiamo
cortesemente di darcene notizia via e-mail e di procedere alla
distruzione del messaggio stesso, cancellandolo dal Vostro sistema.
Conservare il messaggio stesso, divulgarlo anche in parte,
distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per finalità
diverse, costituisce comportamento contrario ai principi dettati dal
D.Lgs. 196/2003.
The information in this message and/or attachments, is intended solely
for the attention and use of the named addressee(s) and may be
confidential or proprietary in nature or covered by the provisions of
privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New
Data Protection Code).Any use not in accord with its purpose, any
disclosure, reproduction, copying, distribution, or either
dissemination, either whole or partial, is strictly forbidden except
previous formal approval of the named addressee(s). If you are not the
intended recipient, please contact immediately the sender by
telephone, fax or e-mail and delete the information in this message
that has been received in error. The sender does not give any warranty
or accept liability as the content, accuracy or completeness of sent
messages and accepts no responsibility for changes made after they
were sent or for other risks which arise as a result of e-mail
transmission, viruses, etc.
