On Thu, Mar 19, 2015 at 11:13 PM, Kevin Smith <ksmith@anonymised.com>
wrote:
I copied the dependency for the JMS clustering modules and just changed
the name. It turns out they have different group IDs. (possibly this is a
mistake and the JMS modules should be in org.geoserver.community like the
other community modulesrather than org.geoserver.)
https://github.com/smithkm/geoserver/blob/bed721032237a7d647926b27d8db0677ddae6cd8/src/community/release/pom.xml#L137
Indeed it looks like a mistake. Opened a ticket as a reminder here:
http://jira.codehaus.org/browse/GEOS-6945
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
