[Geoserver-devel] compiling geoserver 1.3
when i tried to compile this version of geoserver with ant, i had some
trouble with the version of geotools that i was tried, what is the stable
version of geotools which work with geoserver1.3.1 in the subversion?
View this message in context: http://www.nabble.com/compiling-geoserver-1.3-tf4299553.html#a12238099
Sent from the GeoServer - Dev mailing list archive at Nabble.com.
You should be able to compile GeoServer 1.3.1 against the Geotools 2.2.x
branch. We may be able to help more if you include the compile errors
you are getting.
-Justin
Justin Deoliveira
The Open Planning Project
http://topp.openplans.org
