[Geoserver-devel] compiling GeoServer using maven-2.0.4
Hello,
I am trying to compile GeoServer 1.4.0-M2-WCS using mvn compile.
I am obtaining the following error message:
C:\GeoServerWCS>mvn -e compile
  • Error stacktraces are turned on.
[INFO] Scanning for projects…
[INFO] Reactor build order:
[INFO] GeoServer
[INFO] Core Platform Module
[INFO] Data Module
[INFO] Main Module
[INFO] Web Coverage Service Module
[INFO] Validation Module
[INFO] Web Feature Service Module
[INFO] Web Map Service Module
[INFO] GeoServer Maven Plugins
[INFO] Configuration Deployment PlugIn
[INFO] Web Application Module
[INFO] Artifact Merger PlugIn
[INFO] Test Module
[INFO] -------------------------------------------------------------------------
[INFO] Building GeoServer
[INFO] task-segment: [compile]
[INFO] artifact org.apache.maven.plugins:maven-surefire-plugin: checking for upd
ates from central
[WARNING] repository metadata for: 'artifact org.apache.maven.plugins:maven-sure
fire-plugin’ could not be retrieved from repository: central due to an error: Er
ror transferring file
[INFO] Repository ‘central’ will be blacklisted
[ERROR] BUILD ERROR
[INFO] The plugin ‘org.apache.maven.plugins:maven-surefire-plugin’ does not exis
t or no valid version could be found
[INFO] Trace
org.apache.maven.lifecycle.LifecycleExecutionException: The plugin 'org.apache.m
aven.plugins:maven-surefire-plugin’ does not exist or no valid version could be
found
at org.apache.maven.lifecycle.DefaultLifecycleExecutor.verifyPlugin(Defa
ultLifecycleExecutor.java:1281)
at org.apache.maven.lifecycle.DefaultLifecycleExecutor.bindPluginToLifec
ycle(DefaultLifecycleExecutor.java:1216)
at org.apache.maven.lifecycle.DefaultLifecycleExecutor.constructLifecycl
eMappings(DefaultLifecycleExecutor.java:982)
at org.apache.maven.lifecycle.DefaultLifecycleExecutor.executeGoal(Defau
ltLifecycleExecutor.java:453)
at org.apache.maven.lifecycle.DefaultLifecycleExecutor.executeGoalAndHan
dleFailures(DefaultLifecycleExecutor.java:306)
at org.apache.maven.lifecycle.DefaultLifecycleExecutor.executeTaskSegmen
ts(DefaultLifecycleExecutor.java:273)
at org.apache.maven.lifecycle.DefaultLifecycleExecutor.execute(DefaultLi
fecycleExecutor.java:140)
at org.apache.maven.DefaultMaven.doExecute(DefaultMaven.java:322)
at org.apache.maven.DefaultMaven.execute(DefaultMaven.java:115)
at org.apache.maven.cli.MavenCli.main(MavenCli.java:256)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.
java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAcces
sorImpl.java:25)
at java.lang.reflect.Method.invoke(Method.java:324)
at org.codehaus.classworlds.Launcher.launchEnhanced(Launcher.java:315)
at org.codehaus.classworlds.Launcher.launch(Launcher.java:255)
at org.codehaus.classworlds.Launcher.mainWithExitCode(Launcher.java:430)
at org.codehaus.classworlds.Launcher.main(Launcher.java:375)
Caused by: org.apache.maven.plugin.version.PluginVersionNotFoundException: The p
lugin ‘org.apache.maven.plugins:maven-surefire-plugin’ does not exist or no vali
at org.apache.maven.plugin.version.DefaultPluginVersionManager.resolvePl
uginVersion(DefaultPluginVersionManager.java:225)
uginVersion(DefaultPluginVersionManager.java:87)
at org.apache.maven.plugin.DefaultPluginManager.verifyPlugin(DefaultPlug
inManager.java:158)
ultLifecycleExecutor.java:1252)
… 17 more
[INFO] Total time: 22 seconds
[INFO] Finished at: Wed Oct 25 14:56:47 BST 2006
[INFO] Final Memory: 2M/4M
It is unsuccessfully trying to download the maven-surefire-plugin. I can manually download it but where should I copy the file and which configuration file should I change so that it doesn’t try to download it again.
Adit
I think you can probably drop it under your maven repository. If you are on windows, you can find it under Documents and Settings/your_name/.m2/
like this:
C:\Documents and Settings\brent\.m2\repository\org\apache\maven\plugins\maven-surefire-plugin
It will automatically be picked up there.
Brent Owens
(The Open Planning Project)
Adit Santokhee wrote:
Hello,
+ Error stacktraces are turned on.
[INFO] Scanning for projects...
[INFO] GeoServer
[INFO] Data Module
[INFO] Main Module
[INFO] Test Module
ates from central
fire-plugin' could not be retrieved from repository: central due to an error: Er
[INFO] Repository 'central' will be blacklisted
[ERROR] BUILD ERROR
[INFO] The plugin 'org.apache.maven.plugins:maven-surefire-plugin' does not exis
[INFO] Trace
aven.plugins:maven-surefire-plugin' does not exist or no valid version could be
found
java:39)
sorImpl.java:25)
lugin 'org.apache.maven.plugins:maven-surefire-plugin' does not exist or no vali
inManager.java:158)
... 17 more
Adit
Using Tomcat but need to do more? Need to support web services, security?
Get stuff done quickly with pre-integrated technology to make your job easier
Download IBM WebSphere Application Server v.1.0.1 based on Apache Geronimo
http://sel.as-us.falkag.net/sel?cmd=lnk&kid=120709&bid=263057&dat=121642
Geoserver-devel mailing list
Can you reproduce this error over and over? Maven often produces errors
due to servers being overloaded, and running the same command again may
work.
Downloading maven dependencies manually is tricky because you have to
deal with transitive dependencies and timestamps, i don't really
recommend it, although it might just work.
I would recommend removing any versions of the plugin you currently have
in your maven repository and see what happens. If the problems persists
let us know.
-Justin
Hello,
[INFO] GeoServer
[INFO] Data Module
[INFO] Main Module
[INFO] Test Module
[INFO]
[INFO]
for upd
ates from central
error: Er
[INFO]
[ERROR] BUILD ERROR
[INFO]
not exis
[INFO]
[INFO] Trace
'org.apache.m
could be
found
        at
        at
        at
        at
        at
        at
        at
        at
java:39)
        at
sorImpl.java:25)
        at
        at
Caused by:
no vali
        at
        at
        at
inManager.java:158)
        at
        ... 17 more
[INFO]
[INFO]
again.
Adit
!DSPAM:1004,453f6e11127581116498154!
Justin Deoliveira
jdeolive@anonymised.com
Hi Justin,
I have tried this many times. It still gives me same errors.
I have also removed the plugin and unsuccessfully tried.
Adit
-----Original Message-----
From: Justin Deoliveira [mailto:jdeolive@anonymised.com]
Sent: 25 October 2006 16:31
To: Adit Santokhee
Cc: geoserver-devel@lists.sourceforge.net
Subject: Re: [Geoserver-devel] compiling GeoServer using maven-2.0.4
work.
let us know.
-Justin
Hello,
[INFO] GeoServer
[INFO] Data Module
[INFO] Main Module
[INFO] Test Module
[INFO]
[INFO]
for upd
ates from central
error: Er
[INFO]
[ERROR] BUILD ERROR
[INFO]
not exis
[INFO]
[INFO] Trace
'org.apache.m
could be
found
        at
        at
        at
        at
        at
        at
        at
        at
java:39)
        at
sorImpl.java:25)
        at
        at
Caused by:
no vali
        at
        at
        at
inManager.java:158)
        at
        ... 17 more
[INFO]
[INFO]
configuration file should I change so that it doesn't try to download it
again.
Adit
easier
Justin Deoliveira
Hmmm, strange. There must be an issue with your repository. Can you
build if you turn of tests, ie:
mvn -Dmaven.test.skip=true clean install ?
If that doesn't work, and you have deleted the
~/.m2/repository/org/apache/maven/plugins/maven-surefire-plugin
directory from your local repository then log the result of the command
with debugging on (-X) and send it over, I will take a closer look at it.
-Justin
Hi Justin,
Adit
To: Adit Santokhee
work.
let us know.
-Justin
Hello,
[INFO] GeoServer
[INFO] Data Module
[INFO] Main Module
[INFO] Test Module
[INFO]
[INFO]
for upd
ates from central
error: Er
[INFO]
[ERROR] BUILD ERROR
[INFO]
not exis
[INFO]
[INFO] Trace
'org.apache.m
could be
found
        at
        at
        at
        at
        at
        at
        at
        at
java:39)
        at
sorImpl.java:25)
        at
        at
Caused by:
no vali
        at
        at
        at
inManager.java:158)
        at
        ... 17 more
[INFO]
[INFO]
again.
Adit
easier
Justin Deoliveira
Hi Justin,
The log is attached.
Adit
Sent: 25 October 2006 19:05
To: Adit Santokhee
-Justin
Hi Justin,
Adit
To: Adit Santokhee
work.
let us know.
-Justin
Hello,
[INFO] GeoServer
[INFO] Data Module
[INFO] Main Module
[INFO] Test Module
[INFO]
[INFO]
for upd
ates from central
error: Er
[INFO]
[ERROR] BUILD ERROR
[INFO]
not exis
[INFO]
[INFO] Trace
'org.apache.m
could be
found
        at
        at
        at
        at
        at
        at
        at
        at
java:39)
        at
sorImpl.java:25)
        at
        at
Caused by:
no vali
        at
        at
        at
inManager.java:158)
        at
        ... 17 more
[INFO]
[INFO]
again.
Adit
easier
Geronimo
Justin Deoliveira
(attachments)
error.txt (9.69 KB)
Looking at the log maven fails immediately because it could not
download the "clean" plugin.
Is there anything that may be stopping maven from being able to download
dependencies, like a firewall perhaps?
If not, perhaps your maven installation is corrupt. The only other thing
I can think of is blow away your existing installation and try again.
-Justin
Hi Justin,
Adit
To: Adit Santokhee
-Justin
Hi Justin,
Adit
To: Adit Santokhee
work.
let us know.
-Justin
Hello,
[INFO] GeoServer
[INFO] Data Module
[INFO] Main Module
[INFO] Test Module
[INFO]
[INFO]
for upd
ates from central
error: Er
[INFO]
[ERROR] BUILD ERROR
[INFO]
not exis
[INFO]
[INFO] Trace
'org.apache.m
could be
found
        at
        at
        at
        at
        at
        at
        at
        at
java:39)
        at
sorImpl.java:25)
        at
        at
Caused by:
no vali
        at
        at
        at
inManager.java:158)
        at
        ... 17 more
[INFO]
[INFO]
again.
Adit
easier
Geronimo
C:\GeoServerWCS>mvn -X -Dmaven.test.skip=true clean install
Maven version: 2.0.4
[DEBUG] Building Maven user-level plugin registry from: 'C:\Documents and Settin
gs\ads\.m2\plugin-registry.xml'
[DEBUG] Building Maven global-level plugin registry from: 'C:\maven\maven-2.0.4\
bin\..\conf\plugin-registry.xml'
[INFO] GeoServer
[INFO] Data Module
[INFO] Main Module
[INFO] Test Module
[DEBUG] Skipping disabled repository codehaus-snapshot-plugins
[DEBUG] Trying repository central
Downloading: http://repo1.maven.org/maven2/org/apache/maven/plugins/maven-clean-
plugin/2.1/maven-clean-plugin-2.1.pom
[ERROR] BUILD ERROR
[INFO] Error building POM (may not be this project's POM).
Project ID: org.apache.maven.plugins:maven-clean-plugin
Reason: Error getting POM for 'org.apache.maven.plugins:maven-clean-plugin' from
the repository: Error transferring file
  org.apache.maven.plugins:maven-clean-plugin:pom:2.1
from the specified remote repositories:
  ibiblio (http://www.ibiblio.org/maven2),
  central (http://repo1.maven.org/maven2),
  refractions (http://lists.refractions.net/m2/),
  espace (http://maven.espace.ird.nc),
  codehaus-snapshot-plugins (http://snapshots.repository.codehaus.org/),
  geotools (http://maven.geotools.fr/repository/)
[DEBUG] Trace
org.apache.maven.lifecycle.LifecycleExecutionException: Unable to build project
for plugin 'org.apache.maven.plugins:maven-clean-plugin': Error getting POM for
'org.apache.maven.plugins:maven-clean-plugin' from the repository: Error transfe
rring file
ultLifecycleExecutor.java:1269)
        at org.apache.maven.lifecycle.DefaultLifecycleExecutor.getMojoDescriptor
(DefaultLifecycleExecutor.java:1517)
        at org.apache.maven.lifecycle.DefaultLifecycleExecutor.bindLifecycleForP
ackaging(DefaultLifecycleExecutor.java:1011)
eMappings(DefaultLifecycleExecutor.java:975)
java:39)
sorImpl.java:25)
Caused by: org.apache.maven.plugin.InvalidPluginException: Unable to build proje
ct for plugin 'org.apache.maven.plugins:maven-clean-plugin': Error getting POM f
or 'org.apache.maven.plugins:maven-clean-plugin' from the repository: Error tran
sferring file
        at org.apache.maven.plugin.DefaultPluginManager.checkRequiredMavenVersio
n(DefaultPluginManager.java:265)
        at org.apache.maven.plugin.DefaultPluginManager.verifyVersionedPlugin(De
faultPluginManager.java:183)
inManager.java:163)
        ... 18 more
Caused by: org.apache.maven.project.ProjectBuildingException: Error getting POM
for 'org.apache.maven.plugins:maven-clean-plugin' from the repository: Error tra
nsferring file
        at org.apache.maven.project.DefaultMavenProjectBuilder.findModelFromRepo
sitory(DefaultMavenProjectBuilder.java:501)
        at org.apache.maven.project.DefaultMavenProjectBuilder.buildFromReposito
ry(DefaultMavenProjectBuilder.java:225)
n(DefaultPluginManager.java:249)
        ... 21 more
Caused by: org.apache.maven.artifact.resolver.ArtifactResolutionException: Error
transferring file
        at org.apache.maven.artifact.resolver.DefaultArtifactResolver.resolve(De
faultArtifactResolver.java:140)
faultArtifactResolver.java:63)
sitory(DefaultMavenProjectBuilder.java:467)
        ... 23 more
Caused by: org.apache.maven.wagon.TransferFailedException: Error transferring fi
le
        at org.apache.maven.wagon.providers.http.LightweightHttpWagon.fillInputD
ata(LightweightHttpWagon.java:99)
        at org.apache.maven.wagon.StreamWagon.get(StreamWagon.java:68)
        at org.apache.maven.artifact.manager.DefaultWagonManager.getRemoteFile(D
efaultWagonManager.java:369)
        at org.apache.maven.artifact.manager.DefaultWagonManager.getArtifact(Def
aultWagonManager.java:282)
aultWagonManager.java:244)
faultArtifactResolver.java:124)
        ... 25 more
Caused by: java.net.ConnectException: Connection timed out: connect
        at java.net.PlainSocketImpl.socketConnect(Native Method)
        at java.net.PlainSocketImpl.doConnect(PlainSocketImpl.java:305)
        at java.net.PlainSocketImpl.connectToAddress(PlainSocketImpl.java:171)
        at java.net.PlainSocketImpl.connect(PlainSocketImpl.java:158)
        at java.net.Socket.connect(Socket.java:452)
        at java.net.Socket.connect(Socket.java:402)
        at sun.net.NetworkClient.doConnect(NetworkClient.java:139)
        at sun.net.www.http.HttpClient.openServer(HttpClient.java:402)
        at sun.net.www.http.HttpClient.openServer(HttpClient.java:618)
        at sun.net.www.http.HttpClient.<init>(HttpClient.java:306)
        at sun.net.www.http.HttpClient.<init>(HttpClient.java:267)
        at sun.net.www.http.HttpClient.New(HttpClient.java:339)
        at sun.net.www.http.HttpClient.New(HttpClient.java:320)
        at sun.net.www.http.HttpClient.New(HttpClient.java:315)
        at sun.net.www.protocol.http.HttpURLConnection.plainConnect(HttpURLConne
ction.java:521)
        at sun.net.www.protocol.http.HttpURLConnection.connect(HttpURLConnection
.java:498)
        at sun.net.www.protocol.http.HttpURLConnection.getInputStream(HttpURLCon
nection.java:626)
ata(LightweightHttpWagon.java:85)
        ... 30 more
[INFO] Total time: 21 seconds
[INFO] Finished at: Wed Oct 25 19:08:23 BST 2006
C:\GeoServerWCS>
!DSPAM:1004,453fac26161741460912952!
Justin Deoliveira
Blow away: totally remove the repository too, delete
c:\documents & settings\<your user>\.m2 completely (if you're on Windows).
Andrea Aime
I am running it behind firewall actually. I followed the instructions on:
http://maven.apache.org/guides/mini/guide-proxies.html
but it didn't work.
I may have to uninstall everything I guess.
Adit
Sent: 25 October 2006 19:39
To: Adit Santokhee
-Justin
Hi Justin,
Adit
To: Adit Santokhee
-Justin
Hi Justin,
Adit
To: Adit Santokhee
work.
let us know.
-Justin
Hello,
[INFO] GeoServer
[INFO] Data Module
[INFO] Main Module
[INFO] Test Module
[INFO]
[INFO]
for upd
ates from central
error: Er
[INFO]
[ERROR] BUILD ERROR
[INFO]
not exis
[INFO]
[INFO] Trace
'org.apache.m
could be
found
        at
        at
        at
        at
        at
        at
        at
        at
        at
java:39)
        at
sorImpl.java:25)
        at
        at
Caused by:
no vali
        at
        at
        at
inManager.java:158)
        at
        ... 17 more
[INFO]
[INFO]
again.
Adit
security?
easier
Geronimo
Settin
[INFO] GeoServer
[INFO] Data Module
[INFO] Main Module
[INFO] Test Module
[INFO]
[INFO]
Downloading:
[INFO]
[ERROR] BUILD ERROR
[INFO]
[INFO]
[DEBUG] Trace
project
POM for
transfe
rring file
        at
        at
        at
        at
        at
        at
        at
        at
        at
java:39)
        at
sorImpl.java:25)
        at
        at
proje
POM f
Error tran
sferring file
        at
        at
        at
inManager.java:163)
        at
        ... 18 more
getting POM
Error tra
nsferring file
        at
        at
        at
        ... 21 more
Error
transferring file
        at
        at
        at
        ... 23 more
transferring fi
le
        at
        at
        at
        at
        at
        ... 25 more
        at
        at
ction.java:521)
        at
.java:498)
        at
nection.java:626)
        at
        ... 30 more
[INFO]
[INFO]
C:\GeoServerWCS>
easier
Justin Deoliveira
Hello,
It worked finally :~)) I re-installed everything.
Adit
Sent: 25 October 2006 20:07
To: Justin Deoliveira
Cc: Adit Santokhee; geoserver-devel@lists.sourceforge.net
Andrea Aime
I was too quick to jump to a conclusion.
It is actually not completing successfully. I have installed the
jai_imageio-1_1-lib package though.
[INFO] [compiler:compile]
Compiling 104 source files to C:\GeoServerWCS\main\target\classes
[INFO]
[ERROR] BUILD FAILURE
[INFO]
[INFO] Compilation failure
C:\GeoServerWCS\main\src\main\java\org\vfny\geoserver\global\GeoServer.java:
[19,
23] package javax.media.jai does not exist
[20,
[26,
30] package com.sun.media.jai.util does not exist
[51,
22] cannot resolve symbol
symbol : class JAI
[52,
16] cannot resolve symbol
symbol : class SunTileCache
[748
,15] cannot resolve symbol
symbol : class JAI
[752
[51,
35] cannot resolve symbol
symbol : variable JAI
[552
,40] cannot resolve symbol
[555
,22] cannot resolve symbol
symbol : class RecyclingTileFactory
[555
,66] cannot resolve symbol
[556
[557
[560
,28] cannot resolve symbol
C:\GeoServerWCS\main\src\main\java\org\vfny\geoserver\global\xml\XMLConfigRe
ader
.java:[2017,57] cannot access javax.media.jai.util.Range
file javax\media\jai\util\Range.class not found
                                dimensions[dim].setRange(new
NumberRange(min, ma
x));
C:\GeoServerWCS\main\src\main\java\org\vfny\geoserver\config\CoverageConfig.
java
:[209,24] cannot access javax.media.jai.PropertySourceImpl
file javax\media\jai\PropertySourceImpl.class not found
                crs = gc.getCoordinateReferenceSystem();
[INFO]
[INFO] Trace
org.apache.maven.BuildFailureException: Compilation failure
        at
org.apache.maven.lifecycle.DefaultLifecycleExecutor.executeGoals(Defa
ultLifecycleExecutor.java:555)
        at
org.apache.maven.lifecycle.DefaultLifecycleExecutor.executeGoalWithLi
fecycle(DefaultLifecycleExecutor.java:475)
        at
ltLifecycleExecutor.java:454)
        at
        at
        at
        at
java:39)
        at
sorImpl.java:25)
        at
        at
Caused by: org.apache.maven.plugin.CompilationFailureException: Compilation
fail
ure
        at
org.apache.maven.plugin.AbstractCompilerMojo.execute(AbstractCompiler
Mojo.java:505)
        at
org.apache.maven.plugin.CompilerMojo.execute(CompilerMojo.java:111)
        at
org.apache.maven.plugin.DefaultPluginManager.executeMojo(DefaultPlugi
nManager.java:412)
        at
ultLifecycleExecutor.java:534)
        ... 16 more
[INFO]
[INFO] Total time: 14 seconds
[INFO] Finished at: Wed Oct 25 20:50:29 BST 2006
[INFO] Final Memory: 13M/39M
[INFO]
Adit
Well luckily this one is an easy one. You you need to install the java
advanced imaging extensions in your jdk.
http://java.sun.com/products/java-media/jai/downloads/download-1_1_2_01.html
http://javashoplm.sun.com/ECom/docs/Welcome.jsp?StoreId=22&PartDetailId=jaiio-1.0_01-oth-JPR&SiteId=JSC&TransactionId=noreg
-Justin
[INFO]
[INFO]
[19,
[20,
[26,
[51,
symbol : class JAI
[52,
[748
symbol : class JAI
[752
[51,
[552
[555
[555
[556
[557
[560
ader
NumberRange(min, ma
x));
java
[INFO]
[INFO] Trace
        at
        at
        at
        at
        at
        at
        at
java:39)
        at
sorImpl.java:25)
        at
        at
fail
ure
        at
Mojo.java:505)
        at
        at
nManager.java:412)
        at
        ... 16 more
[INFO]
[INFO]
Adit
!DSPAM:1004,453fc17a176402223018498!
Justin Deoliveira
