Hi Gabriel,
I am having some issues getting my environment set up with the complex branch. I checked out the geoserver branch o and it all works great, however I am a little confused about which geotools branch i need. I tried the complex-features branch, but it seems to not match up. Thanks.
Justin
Justin Deoliveira
The Open Planning Project
http://topp.openplans.org
Hi Justin,
to set up the main module as an eclipse project you have to:
1- run maven java:compile (or whatever other target that compiles the code)
2- set java5 compiler options in eclipse
3- add the following folders as source folders:
main/target/generated-src/main/java
main/opengis/src
main/opengis/test
main/opengis/unit
that should be all.
Best regards,
Gabriel.
On Friday 23 December 2005 23:28, Justin Deoliveira wrote:
Hi Gabriel,
Justin
Gabriel Roldán (groldan@anonymised.com)
Axios Engineering (http://www.axios.es)
Tel. +34 944 41 63 84
Fax. +34 944 41 64 90
