[Geoserver-devel] ConcurrentOperationRegistry
I have a question regarding the custom implementation of the JAI OperationRegistry:
https://github.com/geoserver/geoserver/blob/master/src/main/src/main/java/org/geoserver/jai/ConcurrentOperationRegistry.java
https://github.com/geoserver/geoserver/blob/master/src/main/src/main/java/org/geoserver/GeoserverInitStartupListener.java#L128
I’ve checked the code and it mainly replaces the default implementation with a new one using java.util.concurrent locks instead of old JAI locks.
However I couldn’t find any more info about it. Do you remember why was this implemented? Was it just a matter of performance or did you find any concurrency issues? Do you know whether it can have any functional implications or not?
Thanks in advance.
Víctor González
http://geomati.co
It was implemented to get greater scalablity, the registry is called every time a JAI operation is instantiated
from the parameter block and the old implementation was limiting GeoServer ability to run concurrent raster requests.
Regards, Andrea Aime == GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
All clear, thanks a lot!
Víctor González
http://geomati.co
