[Geoserver-devel] Configuration through Database
The current implementation stores the configuration parameters such as Datastores,layers,styles etc in XML files.Can the configuration
be stored in Database tables rather than XML ?
Any ideas ?
Thanks and Warm Regards
Debasish Sahu
Hi Debasish,
it can of course be done, but I do not think anyone is currently planning on doing it. Putting the configuration into a database creates a lot of overhead, especially upgrade scripts, and where to you store the database connection configuration.
I would be interested to know why you need it though?
-Arne
Debasish Sahu wrote:
Any ideas ?
Debasish Sahu
This SF.net email is sponsored by:
High Quality Requirements in a Collaborative Environment.
Download a free trial of Rational Requirements Composer Now!
http://p.sf.net/sfu/www-ibm-com
Geoserver-devel mailing list
Arne Kepp
OpenGeo - http://opengeo.org
Expert service straight from the developers
I was planning to create a database based configuration module for GeoServer.
Can you point me to the java classes that’s needs to be implemented/extended to
implement the same ?
Thanks
Debasish
On Mon, Apr 13, 2009 at 12:29 PM, Arne Kepp <ak@anonymised.com> wrote:
Hi Debasish,
-Arne
Any ideas ?
Debasish Sahu
Arne Kepp
Debasish Sahu
Hi Debasish,
Actually this is something that we have been trying to move toward for a long time, but no easy task. The way our current persistence works is that everything is stored in memory. Are you simply wanting to replace the XML storage format for a database, continuing to load all data into memory? or are you wanting to have configuration driven from the database?
The latter has been experimented with on a branch. You can check out this GeoServer spike:
http://svn.codehaus.org/geoserver/spike/configuration/
However, if you simply want to replace the xml files with a database the class you should check out these two classes:
http://svn.codehaus.org/geoserver/trunk/src/main/src/main/java/org/geoserver/config/GeoServerPersister.java
http://svn.codehaus.org/geoserver/trunk/src/main/src/main/java/org/geoserver/config/GeoServerLoader.java
I would suggest that you work against trunk where the configuration persistence is a bit cleaner than it is on 1.7.x.
-Justin
Can you point me to the java classes that's needs to be implemented/extended to
Thanks
Debasish
On Mon, Apr 13, 2009 at 12:29 PM, Arne Kepp <ak@anonymised.com <mailto:ak@anonymised.com>> wrote:
    Hi Debasish,
    -Arne
        configuration
        Any ideas ?
        -- Thanks and Warm Regards
        Debasish Sahu
        <mailto:Geoserver-devel@lists.sourceforge.net>
    -- Arne Kepp
Debasish Sahu
Justin Deoliveira
Debasish Sahu ha scritto:
As far as I know Simone and Alessio are playing with a Hibernate
based catalog backend in one of these two branches:
http://svn.codehaus.org/geoserver/branches/1.7.x_WCS10EMF_ND/geoserver/
http://svn.codehaus.org/geoserver/branches/1.7.x_WCS10_EMF/
I don't know about their status, or when they plan to start pushing
for a merge back, but there you'll find at least part of the
work already done. I've cc'ed them, but not sure they will answer
before tomorrow (today is holiday in Italy).
