Today I solved
http://jira.codehaus.org/browse/GEOS-5652
with a wont fix. The problem was that the user uses an XML element “password” instead of “passwd”.
There is an example how to add a PostGis database in
http://docs.geoserver.org/latest/en/user/rest/examples/curl.html
This example does not use a password, I am asking myself if we should add an XML “passwd” element to the example to avoid further confusion.
Chrstian
On Fri, Mar 22, 2013 at 4:46 PM, Christian Mueller
<christian.mueller@anonymised.com> wrote:
Today I solved
"password" instead of "passwd".
XML "passwd" element to the example to avoid further confusion.
Seems like a good idea to me
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
