I am well aware that the main/development version is currently 2.25-SNAPSHOT (for six months), but the actual release 2.25.0 is only due in April 2024. Our latest release is currently only 2.24.1. https://geoserver.org/roadmap/
Is it not confusing to users, then, that the title of each documentation page already refers to GeoServer 2.25.x User Manual, as does the heading/breadcrumb:
Yes, the document changes are committed to main and immediately published to https://docs.geoserver.org/latest/en/user/ so technically it is correct.
