Hi, I have problems when adding the support for a database in PostgreSQL 8.1, in the log says :
8250 [GRAVE] org.vfny.geoserver.global.Data - FeatureTypeInfo localPostgis:::departamento ignored - as DataStore localPostgis is broken:java.util.NoSuchElementException: No datastore found capable of managing DataStoreConfig[namespace=topp, enabled=false, abstract=null, connection parameters={namespace=http://www.openplans.org/topp, user=postgres, passwd=post2005, host=localhost, port=5432, database=postgres, dbtype=postgis}]java.util.NoSuchElementException: No datastore found capable of managing DataStoreConfig[namespace=topp, enabled=false, abstract=null, connection parameters={namespace=http://www.openplans.org/topp, user=postgres, passwd=omzeta98, host=localhost, port=5432, database=postgres, dbtype=postgis}]
at org.vfny.geoserver.global.DataStoreInfo.getDataStore(DataStoreInfo.java:232)
at org.vfny.geoserver.global.Data.loadFeatureTypes(Data.java:344)
at org.vfny.geoserver.global.Data.load(Data.java:154)
at org.vfny.geoserver.global.GeoServerPlugIn.init(GeoServerPlugIn.java:109)
at org.apache.struts.action.ActionServlet.initModulePlugIns(ActionServlet.java:1158)
at org.apache.struts.action.ActionServlet.init(ActionServlet.java:473)
at javax.servlet.GenericServlet.init(GenericServlet.java:256)
at org.mortbay.jetty.servlet.ServletHolder.start(ServletHolder.java:220)
at org.mortbay.jetty.servlet.ServletHandler.initializeServlets(ServletHandler.java:445)
at org.mortbay.jetty.servlet.WebApplicationHandler.initializeServlets(WebApplicationHandler.java:150)
at org.mortbay.jetty.servlet.WebApplicationContext.start(WebApplicationContext.java:458)
at org.mortbay.http.HttpServer.start(HttpServer.java:663)
at org.mortbay.jetty.Server.main(Server.java:429)
at org.mortbay.start.Main.invokeMain(Main.java:152)
at org.mortbay.start.Main.start(Main.java:482)
at org.mortbay.start.Main.main(Main.java:90)
Please, What I can do to solve this problem?
Regards.
Regards.
Escapadas, fines de semana, vacaciones, reservas. Organiza y contrata tus viajes aquí. <http://g.msn.com/8HMBESES/2749??PS=47575> ------------------------------------------------------- This SF.net email is sponsored by: Splunk Inc. Do you grep through log files for problems? Stop! Download the new AJAX search engine that makes searching your log files as easy as surfing the web. DOWNLOAD SPLUNK! http://ads.osdn.com/?ad_id=7637&alloc_id=16865&op=click _______________________________________________ Geoserver-devel mailing list Geoserver-devel@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/geoserver-devel
There have been 8.1 issues in Mapserver as well, primarily related to the change in PostgreSQL policy as of 8.1: oids are no longer enabled by default. So if you have code that depends on oid existence, it is time to start deprecating it, because they will become more and more rare from here on in...
P
On 12-Dec-05, at 8:46 AM, Justin Deoliveira wrote:
Can you try the latest version of Geoserver, There have been a few bug fixes to do with postgis. If that doesn't work we can dig a little deeper.
Regards.
