[Geoserver-devel] connection PostgreSQL 8.1
Hi, I have problems when adding the support for a database in PostgreSQL 8.1, in the log says :
8250 [GRAVE] org.vfny.geoserver.global.Data - FeatureTypeInfo localPostgis:::departamento ignored - as DataStore localPostgis is broken:java.util.NoSuchElementException: No datastore found capable of managing DataStoreConfig[namespace=topp, enabled=false, abstract=null, connection parameters={namespace=http://www.openplans.org/topp, user=postgres, passwd=post2005, host=localhost, port=5432, database=postgres, dbtype=postgis}]java.util.NoSuchElementException: No datastore found capable of managing DataStoreConfig[namespace=topp, enabled=false, abstract=null, connection parameters={namespace=http://www.openplans.org/topp, user=postgres, passwd=omzeta98, host=localhost, port=5432, database=postgres, dbtype=postgis}]
at org.vfny.geoserver.global.DataStoreInfo.getDataStore(DataStoreInfo.java:232)
at org.vfny.geoserver.global.Data.loadFeatureTypes(Data.java:344)
at org.vfny.geoserver.global.Data.load(Data.java:154)
at org.vfny.geoserver.global.GeoServerPlugIn.init(GeoServerPlugIn.java:109)
at org.apache.struts.action.ActionServlet.initModulePlugIns(ActionServlet.java:1158)
at org.apache.struts.action.ActionServlet.init(ActionServlet.java:473)
at javax.servlet.GenericServlet.init(GenericServlet.java:256)
at org.mortbay.jetty.servlet.ServletHolder.start(ServletHolder.java:220)
at org.mortbay.jetty.servlet.ServletHandler.initializeServlets(ServletHandler.java:445)
at org.mortbay.jetty.servlet.WebApplicationHandler.initializeServlets(WebApplicationHandler.java:150)
at org.mortbay.jetty.servlet.WebApplicationContext.start(WebApplicationContext.java:458)
at org.mortbay.http.HttpServer.start(HttpServer.java:663)
at org.mortbay.jetty.Server.main(Server.java:429)
at org.mortbay.start.Main.invokeMain(Main.java:152)
at org.mortbay.start.Main.start(Main.java:482)
at org.mortbay.start.Main.main(Main.java:90)
Please, What I can do to solve this problem?
Regards.
Qué hacer en tu ciudad por la tarde y por la noche. No te lo pierdas en MSN Entretenimiento
