[Geoserver-devel] Connection problems in Postgis-backed WFS requests
  Dear all,
I'm not really sure what is the deal here. We have a 2.0.2 install with quite a lot of data, all the feature layers are in postgis. After adding a few more layers, all our WFS requests fail with this exception:
java.lang.NullPointerException
         at org.geotools.jdbc.JDBCDataStore.createConnection(JDBCDataStore.java:1420)
         at org.geotools.jdbc.JDBCDataStore.getConnection(JDBCDataStore.java:1377)
         at org.geotools.jdbc.JDBCFeatureSource.getReaderInternal(JDBCFeatureSource.java:545)
         at org.geotools.jdbc.JDBCFeatureStore.getReaderInternal(JDBCFeatureStore.java:209)
         at org.geotools.data.store.ContentFeatureSource.getReader(ContentFeatureSource.java:481)
         at org.geotools.data.store.ContentFeatureCollection.features(ContentFeatureCollection.java:217)
         at org.geotools.data.crs.ReprojectFeatureResults.openIterator(ReprojectFeatureResults.java:108)
         at org.geotools.feature.collection.AbstractFeatureCollection.iterator(AbstractFeatureCollection.java:334)
         at org.geotools.xml.Encoder.encode(Encoder.java:996)
         at org.geotools.xml.Encoder.encode(Encoder.java:561)
         at org.geoserver.wfs.xml.GML3OutputFormat.write(GML3OutputFormat.java:190)
         at org.geoserver.wfs.WFSGetFeatureOutputFormat.write(WFSGetFeatureOutputFormat.java:137)
         at org.geoserver.ows.Dispatcher.response(Dispatcher.java:726)
         at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:234)
         at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:571)
         at org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:511)
         at javax.servlet.http.HttpServlet.service(HttpServlet.java:727)
It seems related to postgis refusing connection, which is probably related to the connection parameters in the store, which we keep quite low (usually 5 max, 2 min). But if so, I guess I never quite understood how to use that properly. Our postgis has a 200 connection limit, quite high, and postgres reports only 82 in use when geoserver is running. Even if this is the reason, does it mean I am limited in the number of layers unless I put 0 as min connections? Is the latter a possible solution? Or is it something else entirely?
Thanks for any insight, we're running a large system here and geoserver downtime is a big deal for us.
ferdinando
