[Geoserver-devel] Considering a new WMS/WMTS output format: jpeg or png (JPENG for friends)
I would remember image/mixed easier. But will there be need for other mixtures later?
-Jukka Rahkonen-
Andrea Aime wrote:
when working with imagery it happens often enough that one wants the compression
factor of a JPEG, but also transparency at the raster data edges.
Unfortunately one cannot have both… or can she?
With tiled maps we can introduce a new output format, which I nicknamed JPENG
(JPEg or pNG) that would return the right compression depending on the tile content:
if it’s fully opaque, JPEG, if there is any transparency, PNG instead, of course setting
the right return type headers so that the browser can do the right decoding.
It’s simple enough and would save significant bandwidth (and also CPU, JPEG is
faster to compress) for imagery that also needs occasional transparency support.
I’d add this at a WMS output format, and if time allows, WMTS too… but no guarantees,
I have actually no funding backing any of this (I’m doing it for another system), but it seems
quick to implement in GeoServer too and would be a pity to lose it.
Objections? Suggestions for a better name (I checked a few other variants, but they seem to be
already in use on the internet with a different meaning)?
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
On Wed, Jun 8, 2016 at 6:51 AM, Rahkonen Jukka (MML) <
jukka.rahkonen@anonymised.com> wrote:
mixtures later?
Yes, mixed is too generic imho. If we want more clarity, what about
image/jpeg-png ?
Ing. Andrea Aime
@geowolf
Technical Lead
What an interesting problem, I don’t really mind what format is named as. I find image/jpeg-png to be clear, but if other software is using image/jpeng it is worth while to avoid introducing an alternate “standard”.
Aside: GeoTIFF provides a lot of flexibility in encoding contents, including JPEG compression. Is it worth dynamically tuning the image/tiff output compression for the same affect as above?
On 9 June 2016 at 10:40, Andrea Aime <andrea.aime@anonymised.com> wrote:
What NetFlow Analyzer can do for you? Monitors network bandwidth and traffic
patterns at an interface-level. Reveals which users, apps, and protocols are
consuming the most bandwidth. Provides multi-vendor support for NetFlow,
J-Flow, sFlow and other flows. Make informed decisions using capacity
planning reports. https://ad.doubleclick.net/ddm/clk/305295220;132659582;e
Geoserver-devel mailing list
Jody Garnett
On Wed, Jun 8, 2016 at 6:51 AM, Rahkonen Jukka (MML) <jukka.rahkonen@anonymised.com> wrote:
Yes, mixed is too generic imho. If we want more clarity, what about image/jpeg-png ?
Ing. Andrea Aime
@geowolf
Technical Lead
Concur with not using mixed. I'd suggest not using an unapproved mime code (that isn't "real" in the sense that there is no format description document / IANA registration). We probably need to be in the vendor tree, so it would look like:
image/vnd.jpeg-png
There is a x- prefix that can be used for experiments prior to registration.
Brad
On Fri, Jun 10, 2016 at 1:17 AM, Jody Garnett <jody.garnett@anonymised.com>
wrote:
What an interesting problem, I don't really mind what format is named as.
"standard".
Nah, nobody is using it. The other systems we have seen use "mixed" as a
config parameter, but I don't know what they expose.
Unsure... that depends a lot on the user, and GeoTIFF is a different kind
of beast... I would handle it in a different way, allowing
the user to specify what they want like in WCS 2.0, if that machinery gets
built then yes, within that context it would make
a bit more sense to have a way for the user to tell GeoServer to use a
"JPEG or DEFLATE" compression based on whether
there is transparency (but then again, one could argue that in that case it
makes more sense to return a JPEG compressed
image with a binary nodata mask instead... as said, GeoTiff is
complicated...)
Ing. Andrea Aime
@geowolf
Technical Lead
Raising this more as a “something for the future” but it’s related to this discussion: there’s also the WebP format ( https://developers.google.com/speed/webp/ ).
It’s probably not suitable for use yet simply because several browsers don’t implement it, and it’s still undergoing some development, but from a technical perspective as best I can tell it offers both lossy and lossless compression, plus transparency for both types.
The advantage if it ever takes off is that you don’t need to use multiple formats for the “same” content, just a flag for the compression type.
Jonathan
---- On Fri, 10 Jun 2016 12:01:04 +0100 Andrea Aime<andrea.aime@anonymised.com8…> wrote ----
On Fri, Jun 10, 2016 at 1:17 AM, Jody Garnett <jody.garnett@anonymised.com> wrote:
Nah, nobody is using it. The other systems we have seen use “mixed” as a config parameter, but I don’t know what they expose.
Unsure… that depends a lot on the user, and GeoTIFF is a different kind of beast… I would handle it in a different way, allowing
the user to specify what they want like in WCS 2.0, if that machinery gets built then yes, within that context it would make
a bit more sense to have a way for the user to tell GeoServer to use a “JPEG or DEFLATE” compression based on whether
there is transparency (but then again, one could argue that in that case it makes more sense to return a JPEG compressed
image with a binary nodata mask instead… as said, GeoTiff is complicated…)
Ing. Andrea Aime
@geowolf
Technical Lead
planning reports. https://ad.doubleclick.net/ddm/clk/305295220;132659582;e_______________________________________________
