[Geoserver-devel] [continuum] BUILD ERROR: GeoServer JDK4 - GeoServer 1.6.x - Build Def: default maven2 buildDefinition
Online report : http://traffic.openplans.org:8080/continuum/buildResult.action?buildId=512&projectId=27
Build statistics:
  State: Error
  Previous State: Error
  Started at: Mon 17 Dec 2007 12:02:05 -0500
  Finished at: Mon 17 Dec 2007 12:30:00 -0500
  Total time: 27m 54s
  Build Trigger: Schedule
  Build Number: 39
  Exit code: 0
  Building machine hostname: traffic.openplans.org
  Operating system : Linux(unknown)
  Java Home version : java version "1.4.2_12"
          Java(TM) 2 Runtime Environment, Standard Edition (build 1.4.2_12-b03)
          Java HotSpot(TM) Client VM (build 1.4.2_12-b03, mixed mode)
          Builder version :
          Maven version: 2.0.5
SCM Changes:
No files changed
Dependencies Changes:
No dependencies changed
Build Defintion:
POM filename: pom.xml
Goals: clean install Arguments: --batch-mode -U -Djava.awt.headless=true -Dtest.maxHeapSize=128m
Build Fresh: false
Always Build: false
Default Build Definition: true
Schedule: DEFAULT_SCHEDULE
Profile Name: jdk4
Description: default maven2 buildDefinition
Test Summary:
Tests: 203
Failures: 0
Total time: 564.1879
Build Error:
org.apache.maven.continuum.execution.ContinuumBuildCancelledException: The build was cancelled
  at org.apache.maven.continuum.execution.AbstractBuildExecutor.executeShellCommand(AbstractBuildExecutor.java:214)
  at org.apache.maven.continuum.execution.maven.m2.MavenTwoBuildExecutor.build(MavenTwoBuildExecutor.java:138)
  at org.apache.maven.continuum.core.action.ExecuteBuilderContinuumAction.execute(ExecuteBuilderContinuumAction.java:118)
  at org.apache.maven.continuum.buildcontroller.DefaultBuildController.performAction(DefaultBuildController.java:408)
  at org.apache.maven.continuum.buildcontroller.DefaultBuildController.build(DefaultBuildController.java:147)
  at org.apache.maven.continuum.buildcontroller.BuildProjectTaskExecutor.executeTask(BuildProjectTaskExecutor.java:50)
  at org.codehaus.plexus.taskqueue.execution.ThreadedTaskQueueExecutor$ExecutorRunnable$1.run(ThreadedTaskQueueExecutor.java:116)
  at edu.emory.mathcs.backport.java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:442)
  at edu.emory.mathcs.backport.java.util.concurrent.FutureTask.run(FutureTask.java:176)
  at edu.emory.mathcs.backport.java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:665)
  at edu.emory.mathcs.backport.java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:690)
  at java.lang.Thread.run(Thread.java:595)
Caused by: org.codehaus.plexus.util.cli.CommandLineException: Error while executing external command, process killed.
  at org.codehaus.plexus.util.cli.CommandLineUtils.executeCommandLine(CommandLineUtils.java:164)
  at org.codehaus.plexus.util.cli.CommandLineUtils.executeCommandLine(CommandLineUtils.java:89)
  at org.apache.maven.continuum.utils.shell.DefaultShellCommandHelper.executeShellCommand(DefaultShellCommandHelper.java:114)
  at org.apache.maven.continuum.utils.shell.DefaultShellCommandHelper.executeShellCommand(DefaultShellCommandHelper.java:59)
  at org.apache.maven.continuum.execution.AbstractBuildExecutor.executeShellCommand(AbstractBuildExecutor.java:202)
  ... 11 more
Caused by: java.lang.InterruptedException
  at java.lang.Object.wait(Native Method)
  at java.lang.Object.wait(Object.java:474)
  at java.lang.UNIXProcess.waitFor(UNIXProcess.java:165)
  at org.codehaus.plexus.util.cli.CommandLineUtils.executeCommandLine(CommandLineUtils.java:128)
  ... 15 more
